So I went in and talked to the service manager today. He didn't deny that he knew about the TSB. He said he has only had one that he had to repair so far. He said corporate GM said if a spring hasn't broke by 300 miles they probably won't break.
He also said GM told them to run every new vehicle with a V8 for 4.5 hrs at 1800 rpm. If no springs break the the engine should be good to go.
Heard the same thing about running above idle to test.  Seems like "testing in production" to me, which is really the best way in many cases.  Problem is once they've rolled off the line, then the lot, costing the customer money, time, and risk that could be avoided.  General waste for everybody involved.  A good step, but would hope/think there would be a better way to identify which plants/batches installed in what engines and could be dealt with proactively.  Cost of doing business, I guess.
It was all plants, I asked. They put out 65 trucks per hour per plant and I dunno what percentage have V8's. This was over a 105 day period according to GM. That's a lot of trucks and that's not including Cadillacs, Camero's Corvettes, Suburbans, Tahoe's etc.
Edited by Terry Swensen
Wrong word
  • 3 weeks later...
2020 AT4, 6.2L, with around 7,000 miles (heres y'alls evidence for higher milage problems). I dont know the exact build date but purchased around 8/15/20.  Truck died at hwy speed on Christmas eve. Just got the call that a valve spring broke. I believe they said they're only replacing the one spring. I'm no mechanic so I just accepted it until I did a little homework. So from what I've read here, I should be asking for all springs to be replaced per the TSB?
To backtrack....
First, they should be scoping the cylinder to make sure none made it down that far/run a compression test
If all is good, then replace all springs
If there is cylinder scoring/compression loss, replace engine
Edited by Rob Mugs
Yep. 6.2s called for replacing all valve springs. 5.3s called for replacng only the 1 broken valve spring.
Update - dealer did replace all valve springs without any encouraging from me. Fully covered under warranty. Took about 4 days to get the truck back.
*this post didn't quote. This is for the 2020 AT4, 6.2L, with 7,000 miles
Edited by tbbqwebber
Tried to quote post above but didn't. Edited for clarity
Ouch.. 7,000 miles is a long time to be in the "unknown"
@kodiakdenali
@kodiakdenali
I'm having mine replaced, proactively, with aftermarket dual springs instead of factory style bee-hives. this whole thing stinks...but its not worth the stress of the unknown for the next 2-3 years (at the rate I add miles to my truck).
  • 3 months later...
20 LT with 5.3-had 8400 miles b4 valve collapsed and bent a push rod-dealer replaced all valves on one side and was out truck for 11 days-build date 09/20
  • 3 years later...
Hi,
Has anyone got the technical bulletin for the L98 engine valve spring issues; ie valves loosing tension?
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
