49 minutes ago, Boosted16 said:
arent you a mod shouldnt you delete ****** when it gets off topic? youre a bad mod
:rollin:
They also sometimes hand out vacations for foul mouths.
:thumbs:
I'm not just bad at it Boosted, I don't happen to be one.
How funny is that?
:crackup:
14 minutes ago, Grumpy Bear said:
:rollin:
:thumbs:
How funny is that?
:crackup:
thats suuuuper funny man it explains a lot too. That being said the mods are ****ing garbage are they not lol. Wheres my slap on the wrist for cussing on the interent.
Very nice what are your thoughts?
I got one on the work bench at home that I ported the snout myself to work with a Zl1 throttle.  I just haven't had time to install it yet.
contrary to what all the know it alls with stock trucks above say it performs about the same as the l86 manifold from what i can tell on the butt dyno the only noticeable difference is the vacuum it pulls on the boost gauge. Truck still fries tires through 3rd gear
Edited by Boosted16
What throttle body are you running?
l86 87mm. wanted to go with the lt5 but gwatney said porting it wasnt a good idea with boost because the remaining material was so thin
10-4 that was going to be my next question.  When I was porting mine I had to get rid of the stock O-ring.  I'm just going to silicone to ICT adapter to the snout of the intake.
thatll work my man thats what gwatney reccomends you do if you go to a larger tb i know of a guy with the lt2 manifold with a 103 mm tb and a 200 shot of nitrous so they must be able to withstand some torture
Yeah except nitrous doesnt pressurize the manifold or the throttle body, unless there’s a backfire.
ah i see im not really familiar with nitrous but i know plenty of people dont like using plastic manifolds with it while others have no issue at all using them
Edited by Boosted16
reasons
  • 10 months later...
What bolts did you use to bolt you LT2 manifold.  I never installed mine,  then I spun some rod bearings.  So I pulled the motor myself and sent it off to the machine shop.  Now it's got forged daimond pistons 👍.  Since I got it torn apart I'm going to go ahead and install my LT2 manifold.
BUT
I though our L86 bolts are to short so I went to buy LT1 intake manifold bolts and they want 23$ a piece at the stealership.  At 10 bolts that's more than I paid for the intake.🤬
    • 100% agree, there are a lot of variables. I definitely do not drive I’ve like a grandpa but also don’t drive like I stole it. Truck is currently in the shop so I’ll have to get weight later. The price for driving it doesn’t bother me. My precious was a 6.2l so the cost between the two is a wash.
    • if you want a short turning radius get a short bed Colorado!
    • that is pretty awesome MPG there!  I think so far one observation is these trucks do way better on MPG under 65mph vs 70+ and they really suffer at 75+   I noticed on the stretches into NE on 76 and 80 which is posted 75MPH and I was doing 82 I was getting more like 13.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
