11 minutes ago, M1ck3y said:
I may not be blind, but I guess I'm stupid. How are we all assholes, lol.
Well, upbringing, for one thing, and not being able to read through the lines and guess the exact problem with no clues provided.
How could you not tell by just looking at a sitting truck in a picture that it had squeaks and the "Chevy shake"......
Lol dont be stupid man. The truck clearly looks lop sided. Like i said, the truck looks like it had a stroke
The traditional Chevy lean is on the drivers side, yours does look like it is on the passengers side, you may have more problems than you think.
Did you buy it new, if not, any known wrecks the truck could have been in?
Edited by JimCost2014
10 minutes ago, JimCost2014 said:
The traditional Chevy lean is on the drivers side, your does look like it is on the passengers side, you may have more problems than you think.
C850456C-0642-43F2-994A-24F564604843.thumb.jpeg.4449dacd0e1e9965361d8765ce836d9f.jpegThere are times the truck looks perfectly straight. Like right now. It looks fine. The truck was new when bought
2 hours ago, a1smokepole said:
How about the rear view mirror.
i took mine off last month, never been happier, better viewing out the front  and no more accidental emergency dialing onstar when i adjust the mirror ,
just put a 4 inch lif on it and you'll feel better
So you post some random pic of your truck you don't like, and ask us whats wrong....
The poster of the picture.
That's whats wrong.
Go away with you shitty attitude, far away.
3 hours ago, Rodolfo Garcia said:
but anyways all you guys are a bunch of asses. I just asked a question, what kind of forum is this? Assholes.
How's that work in person?
Do the girls like it?
:crazy:
My trailblazer ss leaned to the passenger side. With air bags in the rear and the driver weighing 250lbs at the time. I figured it was adjusted level when I was in it.
do you mean to tell me you didn't know everyone on this forum be assholes...geezz ....da
  • Haha 1
Maybe its just me, but I don't spend time looking at my truck much from the front. Actually not from any angle. I just walk up to it and get in and drive. It's probably because I just don't give a crap enough since its a truck, and if its not something major and it does what a truck is suppose to do, I am good.
Oh I look at mine from every angle possible.
It is .125" low in the back drivers side.
I'll make a shim
:dunno:
  • Haha 1
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
