I am about to buy a new 2021 Sierra next week. I will be going from NC to Dallas to pick it up and then drive back home. With the issues I have read about the fuse block bolts I want to be able to fix it myself before heading back for 1000 miles. What size are these bolts and do I need a short extension? I would really hate to be stuck in the middle of nowhere.
I'm with Jav_eee on this. What issue are you talking about? A few weeks after picking up my 2020 I moved from southeast Virginia to southwest California. I drove the entire way, and had zero problems.
It is either a 7mm or 9/32.  I used the 7mm.  No extension needed.  Can't hurt to check them.  Takes 2 minutes.
Thanks! I plan on checking that before I leave the lot.
What is the fuse block bolt issue? I have a 19 and I’m not aware of this...
There have been numerous posts about the loose bolts in the underhood fuse box causing crank but no start, cel popping up and other warnings. There is even a TSB on it. I just couldn't find the size of the bolts.
Rusty relax and enjoy your drive home, not only will you be covered by GMC's bumper to bumper warranty, but you will have roadside assistance too, I would be more worried about distracted drivers causing an accident or a stone throw chipping your brand new paint, just stay well back from tractor/trailers on the freeway, especially empty flat-beds that are notorious for flying debris.
Edited by garagerog
Interesting. This is the first time I’ve heard of it. Guess I’ll check mine for funsies!
I am trying to be proactive not reactive especially hundreds of miles from home in the early morning hours when no dealers are open.
Usually, by the time they create a bulletin for something like that they have identified and corrected whatever caused the problem during assembly.
So on later built vehicles...
While I totally agree with you, I don't want to take a chance. Like a saying goes, an ounce of prevention is worth a pound of cure. Better safe than sorry.
Bulletin says only 19 and 20 models and not 2021, so don't worry about it.
Me too.....never heard of it.
Guess I'll check the bolts on my 2020 RST just in case.
I've been accused of having a few screws loose, but that's another story. ?
