On 11/19/2020 at 10:24 AM, redwngr said:
Doesn't the wheel tilt enough to see gauges?
Is it the telescoping or non-telescoping?
(telescope optional on LT, but all trims have tilt)
EDIT to add: power seat or manual seat?
Yeah it does but can't see gages when in comfortable spot....only dic.....
Be nice if wheel telescoped and tilted independently
Seats in my 2020 Denali 3500 are garbage.  GM took a HUGE step backwards in seat comfort.  Previous two generation Denali's were some of the most comfortable truck seats I've ever owned.  Personally hoping redesigned interior in 2023 (?) solve this problem.  Denali should bring premium seating materials and comfort.  Swing and a miss on this truck GM.
Couldn't agree more!  I've found a seating position that I don't hate but it is a far cry from the comfort of my 2016 and 2018, I'm pretty disappointed considering I wanted to keep this truck longer than 3 years...
Finally found a decent spot in my 2020 by moving the seat down quite a bit more the I thought I’d like but, it’s not as good as I remember the 16 being. Both were fully adjustable cloth seats. My biggest gripe about the seat itself is that then seat bottom is too short, I actually like the increased firmness on the 2020. IMO the 5 biggest issues that make finding a good position hard in the T1 is, 1) steering wheel height relative to the floor of the truck, the wheel should be coming out of the dash at a higher location by maybe 2-3”, 2) lack of a tilt function on the steering column, I realize you can adjust angle and depth but, I liked the ability to change the tilt of the wheel in a separate function as I like my steering wheel very straight up and down and that’s not possible in a T1 unless you move the wheel all the way down but, then you can’t see the gauges and you hit your leg/knee on the wheel / column 3) the gauges should be lower if the column is going to be where it’s at, 4) the brake pedal is too close to the driver which makes it tough to move your seat close enough to reach the steering wheel comfortably 5) power adjust pedals are GONE on any trim level with any option package, on my 2016 I’d have the steering wheel pulled 80% of the way out and the pedals all the way away from me. Gm would have easily got the $1500 for the Convenience II package if it had power adjust pedals. Hoping that the new gen Tahoe’s have this and I can somehow do a swap.
Also eyeing a katakinz kit in black.
these are exact issues i have with the truck ergonomically......you hit it right on head
My comfort got better as I slowly dialed position in, when I first got the truck I could barely handle driving more than 100 mile trip. Now I can go about 400 miles till I start feeling discomfort. These defiantly aren't  the best seats but does get better with seat time and tweaks.
I agree, the bolster is too short.  With that said, I have been on 6-8 hour trips with no fatigue. I find this kind of funny though, I ordered and received my '15 in summer of '14 and my only complaint was the tilt/telescoping column eliminated the true "tilt" of the wheel and I took some heat over it. Folks are still complaining about it 6 years later and praising the last generation, when the concept was identical.  The tilt radius has been increased so much by moving the tilt joint closer to the firewall, that it's essentially an up-and-down adjustment.  It was a problem seeing the instrument cluster in the last generation, as well, when the seat and wheel was in the most ergonomic position for me. Now a tilt/telescoping wheel and seat design from a 75 El Dorado would be an improvement on these trucks.  ?
On 11/16/2020 at 9:01 PM, edgexcsp said:
I’ve seen a few other posts but no updates or resolutions.  My 2021 Sierra 2500 SLE has to have the worst seat I have ever sat it, the more I drive it the more I hate it!  I’m hoping that somebody will tell me the seat will break in after a couple thousand miles???
This is my 5th GM truck since 2005 and the seat is the worst yet. It’s rock hard and makes my legs fall asleep and my thighs cramp up, it’s like the seat base is too short and the angles are just wrong. I just can’t seem to find comfortable.
We've made several multi day out of state trips in my Sierra and it didn't take long to realize how uncomfortable my seats are. I ended up buying a seat cushion to help: https://www.amazon.com/gp/product/B07MZJGYZ7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I also complained about my seat... I blame the lane assist vibrators as well as all of the complaints above. I find the passenger seat much more comfortable.
But my biggest complaint is the lack of adjustable pedals. like LMCrazy says.. I used a combination of the pedals and seat adjustment on my 2017 to think it was the most comfortable truck I've owned. My wife and I drove it across Canada, down to California and back to Ontario for an 18,000km road trip with our truck camper. Many 12hr days in the seat with no complaints. After 4-5hrs in my 2020 and my right leg and hip get uncomfortable and I get a restless feeling. I also find the lumbar support isn't the same as my last truck and my lower back will start bothering me. And I drive around most of the day to look after multiple job sites so I my truck is my "office" and the comfort matters a lot. One of my biggest complaints with the new body styles..
I have 70k on my truck now, and do find them better as they have broken in a bit... but the base is still hard compared to my 2017 and the seating position can't be changed no matter how much they break in.
I think the quality of the leather in my high country is nice.
However, I’m 6'5 and for my first 15,000 miles I hated the seats, very stiff, and I wish I could raise the Front of the seat more for my long legs.
seat base is too short....and the steering wheel blocks guages as well as brake pedal offset from gas pedal, i guess i am sucker for punishment cuz i just bought a GMC Sierra monday and they are a bit better but still.....in this day and age why is this difficult when older models were so comfy....
8 minutes ago, Lawnboy01 said:
I took out the vibrators. Zip tied them up under the seat. Big improvement
How difficult was that?
I didn't want the vibration but it was the only way to get the HUD so I ordered it that way ... haven't got it yet tho
Had to pull the seat   About 1 1/2 hours to do it.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
