Gonna be honest, I don't know much about different tires. Whenever the subject even comes up I have to look up how to even read the damn numbers & what they each mean. My factory tires are getting close to the end of their life, and I'm considering the Falken Wildpeak A/T3W's. That's what they've started putting on the 2WD work trucks where I work, and the guys say they're great in the summer & the snow, even on 2WD trucks. I asked one guy if he just got new tires put on his truck and he told me "yeah last year." Sounds like they last a long time too. Anyone have any experience with that brand before? So far that's the brand I'm leaning towards when my factory tires are wear out. I don't want to install a lift, leveling kit, spacers, or any other kind of mod. I got my truck with the 20" rims; I liked the look of them better than the 18's. I know the larger wheels sacrifice some of the ride comfort. Anyone know of the biggest size of wildpeak tires that'll fit without lifts, levelers, trimming, spacers, any mods in general, and doesn't have any rubbing? I'm not a fan of super wide tires, I kinda like a stock look, but I want little bigger tires for a better ride, and obviously I want better traction in the winter.
Which OEM tires did yours come with the Bridgestone Dueller A/T's or Goodyears? How many miles you have on them?
Looking to upgrade my Duellers on mine, not sure what I'm going with yet. Looking for something better for the snow/ice drives other than going to a winter only tire, if I did I'll buy another set of rims.
-Grover67
Edited by Grover67
-Grover67
Mine came with Goodyear. They have about 16,000 miles on them and maybe have about 1/4 of their life left.
At3w"s are great tires. I ran them on my 16 Colorado and have them on the 20 baby max.. love them
LD
I am getting these put on my truck (2019 Sierra SLE) as we speak, sticking with stock size (265/65/18) coming from a Goodyear Fortitude HT. Heard a lot of great things about the Wildpeak AT3/W so wanted to give them a try, traditionally been a BFG AT/KO guy on all my trucks so im interested in seeing the difference. Will post pics when I get a chance.
I've had these tires on my 14 Sierra for at least a few years not and a little over 50,000 miles. They have at least another 10,000 miles left on them. Overall they have been good and would recommend.
I just installed some general grabber atx on my silveraldo.  I stayed with the stock size 275 60 20s. Im planning on leaving them on all year and rotating ever 5 or 6000 km. I had them on my old sierra and my old ram and they were great all around tires.
On 12/8/2020 at 8:05 AM, kevlark3029 said:
My brother just put them on his Ford Raptor, but Raptors are a different kind of truck all unto themselfs
How do you like the  Grabbers compared to the P rated tires it came with?  Have any pics with them on?
Edited by cansled
I only got about 60 km on them so far. They pick up rocks really easy, they ride a little stiffer but not alot of differences. The road noise is a slight hum but not overly bad. We have no snow here yet but, I had the same tires on my old ram and they preformed great in the snow and slush. I'll take some pics of them when I get home. I originally wanted the firestone xts but I couldn't get them until January.
Could you please elaborate on these tires as I am thinking of going the same route.   Mainly concerned about the ride of the D rated vs the P rated OEM tires. weight and fuel mileage.  I really love the way the truck is now....except I tow a camper during the summer months and am unsure about the OEM tires!
I had the general grabber ATX on my previous truck (2016 ram rebel).  drove good.  handled good.  Noise was fine on the highway.  way better traction than the toyo tires that came on the truck.
The place I bought them from had trouble getting them balanced (took a couple tries).
They were heavier than the stock toyo tires.  didn't notice any power loss but MPG took a slight hit.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
