I recently Posted about my truck reaching 100,000 miles. It's been flawless, still gets great mileage and runs great. I never installed a catch can and was wondering if any of you guys have gone to 200,000 miles without one and how is your truck performing?
Have you done any valve cleaning in your 100k?
Sent from my SM-N986U using Tapatalk
I think there's just to many variables to compare trucks with the same mileage. How the performance of your truck varied over the last 100 is the best indicator of what you could expect in another 100. That being said, do you have any pictures of your intake valves?
No
No
No
It would be awesome if we could see your valves!
Not sure how relevant it is but when I first got the truck in 2015 just for fun I took it to the track and it ran 15.4's , I ran it again this past fall and it was running similar times, so it didn't lose any power.
I didn't buy the truck to race and I really don't get on to much, but I have a 69 Chevelle and frequent the track with it "the chevelle" often .
My 2016 WT with the 5.3 has 170k on it. Trans blew about 40k miles ago. But the engine is fine.
Sorry about the trans but thanks for the response!
Hello. I had an '08 Yukon (5.3), that I had through 178,000+ miles before I sold it. Never had an oil catch can. Purchased 2020 Silverado (5.3), purchased an oil catch can. 7K + miles and have seen the residual oil. Surprising. Glad I installed the oil catch can.
Am I wrong but before Direct injection , pre 2014, a catch can didn't do anything.
I had a bunch of 5.3's that had big miles no catch can.
Sent from my Pixel 3 using Tapatalk
My boss has a 14 Silverado 5.3 with 240K on the clock. Only thing he’s done is a tranny and torque and oil changes. He drives 140 miles per day to and from work with all of it being interstate. His truck is bone stock and is planning to drive it until at least 350K or more he said. He’s averaging 21.5 too on MPG’s he said.
  • Like 4
Not sure how much they could of helped , the old injection helped keep the back of the valves clean. My son has a 2011 6.2 with 225,000 miles no can and no issues with carbon build up.
I've seen the backs of intake valves from carburetor motors coked closed. Not just a DGI problem. Makes it worse but it is not exclusive. Valve coking isn't totally PCV related. Over rich fueling. Valve guides and seals kill them faster. EGR is a contributor. Add an ineffective oil detergent package and you get a Chia Pet growing in  your intake. And yes PCV IF ring seal in ineffective.
Edited by Grumpy Bear
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,033 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
