Why are so many people with 2019+ GM doing a muffler delete instead of installing a new muffler? Am I missing something lol? Or is it just people going a cheaper route?
Think you just answered  your own question lol
I did the muffler delete on my 6.2 a few months ago. Had them leave both flappers in (the 6.2 has 2, 5.3 has 1) to help prevent drone. Honestly, it's a great setup. It sounds aggressive but not too loud on the highway. I only notice light drone on slight inclines - somewhere around 1700-1800rpm. The best part is it only cost me $75 at a muffler shop. It's a great option if you're looking for more sound. Another option would be to weld a different muffler back in its place which would still get you more sound without having to spend big money on a catback.
I would rather go with new muffler (Borla) than do the cheaper route. It really depends on other perceptions but cutting the muffler is like going back to college where you want to save money but wants to have that great sound that won't hurt your wallet. No offense to those going the cheaper route. Your truck your rules. This is just my own opinion. Respect to other trucks!!!
$300 for a muffler or $100 for a muffler delete isn’t that much of a difference. To me it came down to how it sounds [emoji16]. I may in the future go and put a different muffler on but for now I am letting everyone enjoy it [emoji23]
I have a 2021 Trail Boss with a 6.2 and I cut out the OEM muffler and put a Magnaflow 18" and left the front flapper in place (it only came with one).  I can tell you it sounds great (not too loud) with absolutely no drone.
$60 delete from shop. Everyone thinks I have a $1,200 full system. It’s great and I’ve had it a year.
I have the range technology unit installed so no dropping cylinders with the chopper sound going on. Best $60 I've spent. Range was $180.....still seems over priced for what it does.
Any of you doing this to a lease truck, or do u all own your truck?
I ask because I lease my truck, I have 2 more years left And thought this would be great
does anyone know if it’s hard to have the muffler reinstalled when I turn my truck back in
I own mine.
Has to be cut out and welded. Not impossible but definitely not easy.
Edited by Waymon
Just keep your stock muffler and when it comes time to upgrade/take back the lease just cut the new muffler out and use clamps to put the old one back on
Any videos of muffler delete or Borla welded in but WITH the 2 flappers left, and the resonators as well?
Want to change it as little as possible, but get a bit more throaty and sound better when I get in it.  Would do the borla welded in place, or just delete and do a straight pipe, but was gonna leave the rest as is.
If I switch to a Borla attak muffler only swap. Shoul the Flapper be removed or left in? AT4 6.2 2021
    jaszr2
    jaszr2
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
