I had a 15 with 5.3 AFM. I liked it a lot at the time. I liked my 19 5.3 8 speed even more. Especially after the transmission clunk TSB was figured out. I really, really like my 21 5.3 10 speed. Butter smooth, definitely feels more powerful. My only gripe is the sliding rear window has a tiny drip that neither of the other two trucks has. Point is, until you drive something better, you’ll probably love any of them. They really are all great trucks. I would push for the 10 speed though. It feels ultra refined.
You mentioned:
Silverado 1500 crew cab with a standard bed and 4x4.
Crew cab with a standard bed is a BIG truck.  Most are doublecab/standard or crew cab short.  I had my mind set on the same until I parked it in my driveway and it was up against the door and barely cleared the sidewalk.  If you're hauling drywall and such, might be worth it but I ended up with a short bed.
Just my 2 pennies
You mentioned:
Just my 2 pennies
It’s not that big only about 10” longer
Thats a great looking truck. I hate it when there's more cab than bed...looks like a tahoe that the roof fell off of lol.
Mine is a double cab standard bed but its a dying breed. I bet my next truck looks like yours
I didn’t know you had a standard bed on your truck? Looks nice. I love mine also. That extra room is nice when hauling stuff to the lake.  And the running boards going to wheel well now makes it easy to clean back window and tonneau cover.
That's what sh..........
OK.. I will refrain
  • Haha 3
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
