Was wondering if any of y’all installed a train horn yet on the trucks and where?
Got a trail boss and want some ideas of where to mount it and what kit to buy!
thanks!
I've been thinking about it, but it's very low on my list of things to do. Would be an "appropriate" response for all the a**holes in California.
Oh boy.. just installed the HornBlasters Conductors kit. Oh my is it so much fun. Havent laughed this hard in a long time. So worth it, so loud and sounds exactly like a train. Wow is all i have to say...oh wow!
Installed horns at rear of bed above the drive shaft, and compressor under rear passenger door to the frame. Not that bad.. tight spot to get the horns mounted... just took a test drive..still laughing.. get one!
I have a guy that works for me, he has to be late 50’s. He has the train horns installed on his truck. He thinks it’s the coolest thing and sooooo funny, we just think he’s a doushebah.
Grab a set of truck nuts while you're at it. It'll complete the ensemble.
Thanks for the input, send me a link to the truck nuts please?
6 hours ago, Earl Cordova said:
How old are you ?
Tell ya what. I had a Semi pass me on the Interstate yesterday and got half way past and moved over into my lane forcing me to the shoulder. I hit the weak OEM horn to no avail. I bet is the sound of a train would have got a reaction. 😉
thanks!
My father’s fantasy was mounting machine guns in his grill. And oil releases in the back. Just like train horns. Using them could cause trouble. Especially encountering each other.
I agree that there are such situations where a louder horn can be advantageous.  Air horns used for amusement would have exceptionally limited application unless joy is derived from hurting others.  I do remember in the late 60's  an attention hungry guy in my high school often announced his departure at the end of the day in his air horn equipped '57 Chev.  We'd all stand around, watch and laugh (at him)!
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
