I’ve had my new 2021 Sierra 2500 Duramax for about a month now and love everything about it except for the mileage. I’m seeing around 16 mpg on the hwy running around 70-73 mph and about 12-13 around town. I had a 3/1 level kit installed along with 35/12.50/20 Nitro Ridge Grapplers mounted on 20x9 rims with a 0 offset. Is it the level/tire/wheel package that is killing my mileage?
Yes.
Compare the weights of a stock rim to that aftermarket rim and do the same with your tires. If they added weight to each corner that means it takes more to keep them moving and reduces fuel mileage.
You also raised the front end way up compared to stock so now it's not as aerodynamically friendly, creates more drag and uses more fuel.
From what I have read online that mileage with your set up isn't all that bad.  Could be worse.
It's the width of the tires mostly that dropped your mileage.  Our 2012 with six in lift and 35s gets 15 rather than 18 on the highway because of the lift and tires.  She's shod with Trail Grappler M/Ts.  Each tire/wheel assembly weighs 40 pounds more than stock.
Never seen a Monster Truck yet that gets any kind of good mileage. Lol. All in good fun.
Leveling the truck reduces fuel mileage along with bigger, wider, heavier wheels and tires. Tires have a surprising amount of aero drag. As Earl mentioned, have you adjusted for the gearing of the larger tire circumference?
Despite what anyone on this thread says, those tires arent hurting your mileage bad if at all. I’ve got a 21 that got 13mpg on the road when stock. It’s lifted now and gets 13mpg whether I’m on my 35s or 37s. There’s literally no difference between stock tires and 37’s. These trucks just suck on fuel. My 2015 duramax would consistently get over 20 with 35s.
Ditto nards444 comments, and add that taller tires reduce the numeric axle ratio and lift increases driveshaft angle. Neither "helps" gas mileage. If the mod is for cosmetics its a gift that keeps giving! If you off road in situations that require the additional ground clearance,  its the price of admission.
I still think its funny hearing people talk about putting 35’s on these trucks as if that’s such a massive jump from the factory rubber.
I know. Like the 1/2” height difference will make a measurable difference in axle ratios and drag on a truck with pushing 1000ft lbs of torque. Hope y’all can afford the admission and to pay the fiddler. Whatever that means
It is for me, that's 3.5" taller and usually much wider and twice the weight.
Learned something new today.  It just seems weird that they would have that much of a difference in tires available on the same vehicle.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
