I can't be the only one with this issue, but when the sun is up, the trim around my center console gives off a nasty glare right into my face. Has anyone solved this issue? I have 5 percent tint all the way around, plus the sun strip.
Sounds like a good opportunity to change it to a custom matte paint color or plastidip or something like that?
Not the same vehicle but the same problem. I keep a shop towel handy and just cover it. On the bike I found a black powder coated part to replace the chrome. A wrap would work.
I can't stand chrome. why do manufacturers put it on the interior of a car of all places? its so hard to remove from interiors because the chrome parts are often so small and difficult to remove, paint, or wrap without damage. for the exact reason you see there, it seem to be a safety hazard! I once drove a Dodge Charger that was probably the worst of all. if the sun was out no matter what direction you were traveling some piece of interior chrome reflected the sun directly into your eyes. it had this big CHARGER badge on the passenger's side dash, all chrome, you'd be seeing spots if that thing caught the sun. then just as you round the corner expecting relief the sun hits the big chrome driver's door handle and now your other eye is blasted...
I haven't put much effort into removing the chrome on the interior of my truck, especially because it seems to be a brushed chrome, its not quite as mirror reflective as the exterior stuff. (it still reflects the sun into your eyes just as easily as the mirror chrome though) but I'd look into a vinyl wrap or something to cover it up. no only will it solve this dangerous situation, but it would look so much better.
I saw a picture somewhere on this forum of someone who had their interior chrome wrapped in a matte brushed copper vinyl or something similar to that. it looked really good.
My Camaro has the exact same issue between 12 and 1 pm.  The chrome on the dash around the gauges will blind you.  I agree that I don't know why they put these crap chrome pieces inside or outside of vehicles.  Chrome should be an extra add on and the default state of a vehicle should be color matched on the outside and brushed chrome or whatever that won't reflect the sun right into your eyes.
Best thing to do is get a vinyl wrap and it'll solve the issue.
I had to vinyl wrap mine. It did it twice on the way home my first week of ownership and I remedied that this weekend.
How did you vinyl wrap it
I took a 2  inch wide strip of 3M vinyl and then used a sharp exacto knife to trim the excess.
I was thinking of asking for tips since I haven't done this myself yet. did you take any of the pieces off or do the work with them installed? many of the chrome pieces are actually separable from what's around then. the ones around the LCD screen for example are attached with screws and some melted plastic tabs. you'd have to break the tabs, but they should be able to reinstall pretty easily. I'm wondering if all of that is worth the effort to be able to wrap the vinyl around behind the piece to prevent any chrome peeking through or if its possible to do just as good a job without taking things apart. any advice?
could you post some pictures? I'd really like to see how it came out.
did you attempt the door handles by any chance? they will be tough due to the shape, I'm wondering if the chrome part of those can be removed somehow so the vinyl can be stretched and wrapped around the back.
3/0 heat shrink tubing works wonders on the handles.
15 minutes ago, kodiakdenali said:
Interesting idea, what about the open end though?
Yep, doesn't shrink closed. Yep, shiny handles are black. I tried one of those black rubber caps on the end and shrunk around it, but the handles aren't round and it looked goofier that a half closed end that you don't really see.
I would need to research a lot more to see what products are out there, but it appears that there at least exists some "end cap" heat shrink tubes, the largest ones here are about 4.5" long, basically a piece of heat shrink but with one end capped off instead of just open. this could be a great solution to the door handles.
https://www.amazon.com/Heat-Shrink-End-Cap-Pieces/dp/B00ZYTQ7A4/ref=sr_1_3?dchild=1&keywords=heat%2Bshrink%2Bend%2Bcap&qid=1618499373&sr=8-3&th=1
much better options than amazon:
https://www.mcmaster.com/Heat-Shrink-Tubing/heat-shrink-tubing-type~end-caps/
unless some company out there would be able to make a perfect fit flat black silicone cap that can be installed over the handles and easily removed if you want to sell and the new buyer likes chrome.
Edited by kodiakdenali
I was thinking of asking for tips since I haven't done this myself yet. did you take any of the pieces off or do the work with them installed? many of the chrome pieces are actually separable from what's around then. the ones around the LCD screen for example are attached with screws and some melted plastic tabs. you'd have to break the tabs, but they should be able to reinstall pretty easily. I'm wondering if all of that is worth the effort to be able to wrap the vinyl around behind the piece to prevent any chrome peeking through or if its possible to do just as good a job without taking things apart. any advice? could you post some pictures? I'd really like to see how it came out.
No, I didn't attempt the door handles, because I didn't really intend on doing a full blackout job. I just couldn't deal with the glare. You have enough of an edge that as long as you use a sharp enough knife, you can cut around the edges. I used a mini squeegee to get it laid down tight to the edge and then cut the excess. I'm by no means a professional and there are small chome gaps. But it's far more tolerable than getting blinded by the sun. Just make sure you buy a minimum of 4in wide vinyl or you will have to do a ton of stretching like me. 226418daa3a1f4f17a54b1530f999474.jpg20149e1f5f4cefe4cca72c9c37910085.jpg
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
    • I had a Gen5DIY DRL relocate harness from a 2022 1500 that I saved. I had Gen5DIY modify the harness for my 2024 Silverado 2500. Plug n Play, worked perfectly.    Here's a video I made for the 2022 1500 truck. The install is more or less the same on a 2500.    The harness relocates the DRL tot he top amber turn signal on my 2500.
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
