2 hours ago, Amcguy1970 said:
These posts always crack me up, 3 people here have it, 3... A few people with the issue or a small handful all of a sudden it is labeled as common issue that almost every truck has when it is probably a 0.000X% of people that actually have had the issue. Lets not make it something it isn't, people did that with the AFM failures and valve coking to name a few; made it out to be some common issue when very few even on the forums had it where most people go just to complain.
Tyler
I would disagree with you. I’ve noticed dozens of GMCs with this same issue in the smallish town I live in. I’m not making the claim due to 3 people on this forum and I’m not labeling it that every truck has this issue. Obviously it’s a somewhat small percentage of overall trucks on the road, but it’s still a prevalent issue.
Yep , a couple of our work truck sierras had them.  Made Appt and GM just replaced the headlights. ( both are 20 MY) while my 2019 Sierra does not have the BLUE .  Interesting now as i drive around town , I will see a couple here and there with the Blue.
I would think its a simple issue but when your replacing headlight housings , there is something else going on.
Yes hilarious. 🙄
I have a 21' sierra 1500 denali 3.0 w) same issue on driver side top drl is purple-ish.
Make that 5 people.
same issue on my 21 Silverado. didn't notice it until a few weeks after buying the truck.
1 hour ago, DCazares said:
I see this all the time, I just wonder if the owner even realizes the defect.
I think mostly only the OCD people, like the majority of us on these forums even notice or care. Haha
Finally got time to take to the dealer and was replaced without question. Glad to finally have it done. Was driving my ocd off the wall haha
Does the new one match up color wise to the old light? Not to get you all paranoid or anything hahaha
After reading this I looked and my 2021 delivered in late March has the issue on  the drivers side light  too so its still out there.
Is the LED's bulbs going bad somehow ? Never seen them going from white to blue .
Maybe someone with Light/electric knowledge can chime in . ( Yes I know its not a big deal , but same time the OCD in me says get it fixed )
haha yes sir it does. I was worried about the same thing initially
So.. interesting twist of fate... got the drivers side headlamp assembly replaced... its already starting to turn blue LOL
Wow... there is something deeper going on here... why is it that mostly it’s the drivers side going bad? And so quickly. Seems they are faulty/failing straight from factory.
I'm guessing large (YUUUGE) bad batch of these I'll try to get the date code off of this one, our truck was built in Oct '20 though so thats a hell of a gap if this is fresh-ish stock from GM.
On 4/28/2021 at 2:13 PM, 1badc5 said:
There are a lot of post about the DRL turning blue on FB groups. I didn't see any post on the forum so thought I would start one so everyone could share if they are having same problem.
I have 2020 AT4 with 22K miles. Just had dealer replace both headlights because of them turning blue.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
