I would look at the math for each motor.  You drive X miles per year averaging X miles per gallon (guestimate) X the price of each type of fuel = yearly cost.  If the difference is say $500/year = $41/month = $11/week, is that gonna kill you?  You could include the motor price surcharge over, say 5 years (6.2 is ~$2500, so $500/year).  Add that to the yearly cost.  Is the additional $$ for each motor material to you?  What are you actually saving by going with the 3.0 or 5.3?
Also, consider the "fun factor" of a 6.2 which you can't quantify but is a factor.
My .02.
Edited by cltsig
My .02.
Don't forget, the 6.2 is a $2500 upcharge option.  Nothings free, lol!
Never mind, I see you added that in
Edited by steelcity
23 hours ago, ccoon21 said:
Adding the heavier tires that I need for being off-road also concerns me for fuel economy.
Do you really need bigger/wider tires for where you drive to the boat launch or deer camp?
If you are really concerned with fuel economy, I suggest you look for some good tires that are closer to OEM size.
The 5.3 with more gears should suffice for everything you need it to do. ( I have a 6 speed 3.42)
If you want the 6.2 just for the "fun factor", that is purely up to you and not a financially driven decision.
Not so much for the boat launch but some of the deer camp’s roads have parts that can get real sloppy or washout with a little rain, I’m better off having them than not.
I appreciate y’all’s responses. Looks like I still need to do some research. (Kind of surprised not as many people mentioned the 3.0 considering I’ve read a lot about it in other threads)
I have driven the AT4 (about 95% sure that’s the trim I’ll be going with) that had the 6.2 in it and to say it was fun to drive would be an understatement. I’m just not sure how practical it is for me at this point though.
As far as the 3.0 diesel goes I am not all that impressed. My neighbor has one that I drove and it was on par with my 5.3 I had. Off the line it was good, but passing and merging into traffic is where it fell behind. Remember 460tq. but only 277hp. Sure it will get better fuel milage but there is a much higher maintenance cost in Def and oil and fuel filter changes. Don't forget about that water pump belt that needs to be changed at 140,000 miles in which you need to pull the transmission to get to it.
I just picked up the 5.3/8 speed elevation. All my driving its stop and go traffic. I get about 17mpg. Not bad considering my Rebel used to do about 14mpg on the same trip.
Edited by dv_damian57
I say test drive them all and see what you think.
I've got a loaded 21' 3.0 and have been extremely pleased with it so far. Tows my 5K lb. boat like a dream.
My overall fuel economy is ~22.6 mpg.
Yes, you will eventually have to have the oil pump belt replaced at 150,000 miles. Yes, you have to add DEF from time to time (not a big deal really).
I suspect from my past experiences that the resale on a 3.0 will be worth more than its gas counterparts. Something to consider.
A 6.2/10 speed combo would be great fun for sure. I just didn't want to feed that beast.
Edited by SVG
spelling
Something else to consider is the drive train warranty on the diesel is 5yr/100K miles vs 60k miles on the gas.
Have 2021 Silverado Z71 6.2 10 speed 3:23 gears, Just pulled my trailer 1500lb steel trailer with a 2007 5000lb. 1500 over 200 miles and avg. was 13-14mpg mix highway and back roads.
Truck alone I average 20mpg
Edited by WeGone
DEF is a non-issue.
If mileage matters I ran a 2015 6.2L 8spd and a 2016 5.3L NHT 8spd to dping the same job as current 3.0L 10 spd.
It has tow mirrors, like an NHT did, but NHT and tow mirrors are now separate options.  And NHT is not available on 3.0L.
I log fuel purchases.  The '15 and '16 both got between 20 and 21 mpg -- when tracked by the tankful.
Purchase truck last fall.
I was planning to wait until I got the def empty message, but had to make a trip far enough from home territory that I made the decision to go to a bulk pump and fill the def tank.
DEF gauge had the small led and one full size led on. Book for 3.0L says this means 4 gallons can be added.
iDash said it was at 10% remaining. Math says that means 90% x 5.3 = 4.77 gal can be added.
Last filled at a bulk pump at 733 miles. This time 8674 miles.
7941mi between fills.
Pumped 20.89 L for C$18.78
This is about 5.52 USgal (yes, more than it is rated to hold) and about US$15.00.
I suspect, but don't know for sure, that the rated tank size and the size iDash uses does not include the fill tube, which I think was filled before the nozzle on the bulk pump kicks out.
7941mi /5.52gal = 1438 mpg def.
$15/7941mi = US$0.0018 per mile.
Truck has run 26.5 usmpg over same miles.
Since the 5.3 is out, 3.0 diesel IMO.  And that's even considering maint. costs.  Fuel savings alone over 5 years is huge.  Plus it ticks your commute and if your trailers are say 8000lbs or less it can tow them non issue.
The 6.2 really truly loves 93.  Can you run it on less?  Sure, but your performance and mileage will hurt.
Here's a nice shot using the AT4 in 3.0, 5.3 and 6.2 form:
$6,250 MORE in fuel over the 3.0 over 5 years.  About $1200 a year more.  Even if you factored in say $70 oil change/rotation every 6,000mi for gas engine, and $100 every 6,000mi for the 3.0 diesel and heck, even DEF, the diesel would still be cheaper.  And the initial purchase price will be less than the 6.2.
Edited by newdude
I like that graphic. What website is that on?
Thanks. I bought it on ebay. There are 3 different styles and a few color options as well.
    • I had an issue with a new 1985 Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
