Same, mostly XM, never terrestrial (commercials galore) radio.  I have no antenna and used a little plastic plug I bought at Lowes to fill the hole.  Has never popped out even through car washes.
3 hours ago, gemarsh said:
Works for frequency modulation.
Does it shut Karens up, or make desperate mommies wet themselves?  Just trying to figure out what frequency you ended up on, lol.
Here's what I went with.  Got the 6-3/4" in black.
AntennaMastsRus - The Original 6 3/4 Inch is Compatible with Chevrolet Silverado 1500 (2006-2021) - Car Wash Proof Short Rubber Antenna - Internal Copper Coil - Premium Reception - German Engineered https://www.amazon.com/dp/B01MY0NH60/ref=cm_sw_r_apan_glt_fabc_15706JRG4X1FJAH773ZG?_encoding=UTF8&psc=1
I have the 15" stock style from Antenna Source. No difference in reception at all.
I use this one also transferred it from my 2018.
This is the one I got as well. Works just fine.
What's the frequency, Kenneth?
i went with this bad boy and haven't had any reception issues https://www.amazon.com/gp/product/B07RXRNTW8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Works as good as the stock one for me. Holds up in car washes.
I bought the Rydonair 9" via ebay (brand new). Great reception, great looks. and doesn't hit my garage door frame (which was the whole reason I wanted something shorter)
2nd this recommendation. I listen to a lot of terrestrial radio (both AM and FM) and get same reception as OEM with this antennae.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
