I got a message today on my info screen that the truck has an update.  I’ve never had this before.  Is this common?  Are there any pitfalls I need to be aware of?  I’m just thinking how often updating my phone or computer causes problems that I really don’t want to deal with.  I really don’t want to deal with it with my main mode of transportation.
Be sure you can leave the vehicle while the entire download happens....dont turn off or on unless instructed.  As above, it will eventually force you...better to choose on your time where you can wait for it...also park outside so no issues with interference.
I keep reading about these updates, I wonder what prompts them as not everyone is getting them?
Mine is a 3/21/21 build with version 153.
I have no idea how to verify my version.  The build date of my Sierra is 3/1/2021.
I recommend you install the update.  I noticed this morning that my radio wasn't shutting off when I opened the door.  I immediately started checking for a software update.  Sure enough it was out there.  I downloaded the update and now the radio shuts off like it's supposed to do when the door is opened.
Typical update.  Since updating I’ve had two instances where Apple Play doesn’t work correctly.  Had to use my phone to get Waze to work.  After putting in a location, it has locked up.  Needed to use phone to get out of Waze and back in to get it to work.  Ugh.
V155 was supposed to correct Apple CarPlay issues. I have a ‘20 that CarPlay hasn’t been reliable since new. Chevy will not install the update for me so CarPlay is hit or miss for me.
  • Thanks 1
Is this update only for the '21 model year?  I too have a '20 and no update.
I have a '21 and no update either. I've gone to settings>update, but it says I am up to date even though I'm on version 153.
Last weekend I took it in for the first oil change and asked that they update it. When I got it back it was not updated. The note on the service reports said it was already up to date??
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
