I can only buy 91 octane Premium around here,  93 is no where to be found.
Bought my truck brand new with 5 miles on it.  I mentioned it to the dealer when I test drove it.  He told me they "all do it".  26k miles later and it stills does it, but I'm not worried about it because if it was something to worry about, it should have gotten worse over the miles and it hasn't changed a bit.  I live in California, so 91 octane is all we get.  may give the Amsoil stuff a try and see how it goes.
Disabled by the actual Pulsar LT or the Range AFM/DFM disabler? The AFM/DFM doesn't work on the 2019+ 10 speed trucks per their website: The AFM/DFM Disabler is NOT currently compatible with 2019+ 5.3L 10-speed or 6.2L 10-speed models.
I had the same question on my 6.2. Was about to run a “cleaner” through but checked fuel trims to see if injectors were dirty, after 40k miles, they’re nearly perfect…. So unless there’s some other fuel related issue, they probably just idle a little rough.
fwiw, my afm is disabled
Ok thank you I might try some of that amsoil fuel treatment and see if that helps
My point in writing was that the motor is running perfect if fuel trim is near zero.
not sure what may be causing idle to seem rough but I don’t think there’s any problems or any fuel related system to be cleaned.
So I looked further into it and seems mine is the motor mounts.  I found a service bulletin out for it and says they are either faulty or need shims.  Taking it in Monday and I’ll keep everyone posted
Motor mounts don't help.  I had to show the dealer that the truck had rough idle when in gear.  They were observing in Park and it ran smooth.  Traded the day after motor mounts didn't fix it.  2018 GMC 5.3L 8peed 4wd.  Did the rough idle from 300 miles on.  They wanted me to pay to have the fuel system cleaned at 35900 miles.  I explained it was doing the rough idle on the first tank of fuel.
Currently have 2021 GMC with 3.0 duramax.  I have had enough of the GM gas engines. This one doesn't always start on the first try, but runs smooth as silk when its running.
Did you have your motors mounts replaced ? And it didn’t help ? Ugh so frustrating.  Mine vibrates so bad when in park and in drive.  On the highways it’s smooth
On 10/17/2021 at 8:40 AM, Rcfire said:
yes, they replaced the motor mounts.  No difference.  Treating a symptom of the skip doesn't fix the problem.  I believe its a known issue that they don't consider to be a problem.  It was embarrassing when passengers noticed it.  Only issue that truck ever had, I was happy with it overall.  But I am glad its gone.
I'm on my 3rd 6.2 since 08, this one is the smoothest (21 6.2) with foot on brake, but still has a little shake from time to time.  When I was getting the 08 tuned Justin mentioned to me that the truck is idling at some stupid low RPM and like lpg mentioned adding a little RPM will smooth it right out.  He added a little to show me and then went super smooth, but then set back to stock range.  If you leave the stupid stop/start on less shake time haha.
On 10/4/2021 at 8:33 AM, Black02Silverado said:
Mine is a smooth idle.
Not starting anything but do you run 93 octane?
Yes I only
run 93
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
