I have a 2020 Denali with the 22” tires. To say I am disappointed in the performance of the tires would be an understatement. It has trouble coping with 2” of snow on a slight slope. It now has 3900 miles on it and with winter coming on I don’t want to go through another winter with these junk tires. I had a 2000 Sonoma highrider with 15” x 33 BFGs and never worried about the weather. The truck isn’t leveled which I think may limit my choices. I don’t believe I can put BFGs on the 22”s without doing some drastic lift. I am seriously considering a leveling kit but not sure what I should go with.  I am also considering 18” wheels so I could go with a decent tire such as BFG KOs. Any suggestions or help is welcome as I am basically new to the Sierra. Thank you.
On my Chev I have a set of winter tires/rims (18") that I put on for the winter. Living at 7000' and driving in the mountains it makes a huge difference. I agree the factory 22" tires are not very good in the snow.
Jay
Get a set of takeoffs and put some snows on them.  You won't trash your nice wheels and you can just swap them on and off before and after winter.
Finding 17"s or 18"s should be pretty easy from a 2019+up new body truck.  TrailBoss/AT4 would make a good option for takeoffs as many of them have Goodyear Wrangler Duratracs already on them.
Your closest match for the speedo without going to some big honking tire would be 275/70R17, 275/65R18 and 275/70R18.
Its pretty clear from the tread on those 22" that they are a 3 season tire.
ALSO...stock 275/50R22 tires are 33" diameter, so a 33" tire on any stock wheel size should fit, so long as its not too much wider.  275 wide is a sure fit, you might be able to go 285 wide on stock wheels either 17, 18 or 20 inch.
Edited by newdude
Michelin makes the Defender LTX in that size, they are a great tire for all year round use.
If your truck came with Michelin Premier LTX's they are pure garbage in my eyes. They are a super nice ride but that's all you get, they spin in the wet with enough power and suck balls in the snow.
My other suggesting for a stock size tire for the 22's are the Pirelli Scorpion Verde AS Plus2 or 3, they are good all around tires too.
I find it interesting that All Terrain tire options are limited for these trucks.  The short sidewall must make the manufacturers  nervous. Having said that, there are quite a few 22" wheels delivered on these trucks, so you'd think there would be more options.
BFG does have a 22" AT tire, it's available in 33X12.5R22.  However I don't think there's 12.5" available for tire width on these trucks.  I'd very much like to be proved wrong.  I'd like to see pics of a 33X12.5R22 on a stock level, if anyone has done that.
Nitto 285/55r22 options that fit are available, for a more AT stance than the Michelin Defender. I've also read that the Nitto 305/45r22 fits stock, as well
There aren't many AT options because a low profile AT tire on 22" wheels makes zero sense.  22" wheels usually get a street tire.  There are many options for those.
The OP started this with a complaint about snow performance. The issue with the 22" street tires in this case is the snow performance.  I don't think many on this forum would go serious off-roading with 22's.  Low profile 22's with an aggressive tread make more sense in a snow environment.  There are *not* many options for those.
Thanks a lot for the input. I am thinking about going with a set for the winter and thinking about takeoffs. Really not sure if they did anything with the brakes on a 22” truck that would hurt me if I went down to an 18” or 20”from an AT4, I don’t want to run spacers.  Sounds like I’d be ok.
CamGTP - the tires are the Bridgestone Alenza and it sounds like they are as bad or maybe worse than the Michelins you mentioned.
One other question - when you swap tires/wheels, does the sensors automatically sync with the computer or do I have to invest in an overpriced tpms tool? So far the dealership has been covering the maintenance but I’ll be doing it next oil change which means tire rotation.
Thanks in advance.
You have to program the sensor.
The TPMS tool is like $14 on amazon and they work great.
I have 285/55/r22 Nitto ridge Grapplers on my stock 22” wheel with spacers and a 3.5 inch lift and I still had to modify the inner fender and the mud guards for them to fit. I was planning on going with 285/50/r22 (I would still need to do modifications with this size as well) but there were only 2 AT tire options worth purchasing in that size. I did a ton of research before my lift and tire purchase and what I learned is not all tire manufacturers have the same exact sized tire even tho they say “285/55/r22”. They will range from 33.5”- 34.5”. That 1 inch may seem small but it’s the difference between your tire clearing or rubbing in places it should not touch. 285/55 and 285/50 from my experience will not fit a stock height Denali. (I own a 2021 Denali 1500)
I agree with the Michelin Defender LTX, they are great in winter conditions.
Thanks in advance.
I think the spare under your truck will be a 17" rim -- which would answer your brake size concern
QAQ Tire, spare 255/80R17SL all-season, blackwall
1 - Included and only available with (QAB) 275/60R20 all-season, blackwall tires.
2 - Included and only available with 20" or 22" wheels and tires.
Standard on Denali
Note 1 = base truck
Note 2 = SLE/Elevation/SLT/AT4
(The other 'spares' used are also on 17" rims.)
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
