Window sticker on my truck says it should have heated mirrors.  Now that weather is turning, I am questioning whether it actually does.  I don't see the marking on the actual side mirror and don't see the results with defrost running.  Wondering if this is a chip supply chain issue surprise.  Haven't had a vehicle in at least 20 years without that feature.
Can anyone who has this feature confirm whether there is a marking on the mirror itself?  How else could I confirm since it is not clearing moisture quickly?
They should come on with the rear window defroster. (button labelled 'rear', at the 7 o'clock position)
I'm not aware of any markings on mirrors (but also not sure that there isn't a way to tell)
As you are aware, heated mirrors are standard on most trims (available, but not standard on Base sierra and on WT)
On tow mirrors, only the upper glass is heated.
If you have a temp gun it might be able to help diagnose.
Edited by redwngr
Yea you have to hit the rear defrost button. Turning your climate control to dash/ windshield vents will not turn on heated mirrors.
Edited by Adamace1
For my truck;
RPO: DLF
" MIRRORS, OUTSIDE HEATED POWER-ADJUSTABLE"
Manual states that you have to turn on the rear defrost to have them turn on. Unless you do not have a rear defroster.
Heated mirrors were not on the chip chopping block.
They come on when you turn on the rear window defogger.  On the same button.
Edited by newdude
Thanks for the replies.  I did check the manual and understand aligned with rear defrost.  Maybe they are just not as responsive as I remember on my previous truck/vehicles.  Cold weather season is coming!  I'll get more tests soon.
The Layman's way to test (have done it myself), is to turn them on when it starts getting cooler in the evening, early morning, and just breath on them. If they are working, you will see steam on the glass, then it should start to disappear from the heat generated by the mirror.
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
