16 minutes ago, MORSNO said:
Your occasional towing didn't cause an excessive oil consumption, I'll bet they didn't add the correct amount of oil at your last oil change.  Most V8's are 6 quarts, your engine is 8 quarts and your truck was shorted 2 quarts.
This 👆is very likely a plausible explanation. Heard of it many times in recent years with engine config changes or different engines than usual. Many places/techs get accustomed to Make/Model takes "x" quarts, so it becomes habit and sometimes they don't look it up to be sure. Could have thought it was the regular 6.0 gasser, put in 6 qts and was done. Never realized the new gasser was a 6.6L and took 8 qts.
I'd make sure it got 8 next time and keep an eye on it to be sure.
Also. you have to wait a good 20 minutes after shut down to check the level.  Seems weird but at least on my 6.2.  I checked it about 2 minutes after shutting it off and it was at the add mark.  I then waited until the next morning and it was at the full mark.
Side note, that is some pretty low fuel mileage for that many miles driven lol. Towing surely does that though, or maybe he drives really fast.
8 mpg!!
Regarding oil change interval discussed above, it’s a good idea to do some research to understand the intake coking issues that some fear will be caused by the direct injection system eliminating fuel washing of the intake areas of the cylinder heads, and the resultant potential for oil deposits to form from the crankcase ventilation system introducing oil vapor and oil condensation in those areas. Other direct injection engines have had problems from that. Part of your defense against that is the additive set in the Dexos approved oils. Those additives break down over time, and you should consider that in deciding on your oil change interval. See the threads on direct injection and on catch cans for discussions of the coking issue.
Where all 5k of miles using 700 gallons towing? If so , that indicates about 7.8 mpg! Thats seems to indicate some pretty aggressive/high speed towing habits for that weight or a high % of hilly terrain. If there is any non towing miles in that figure it is more perplexing. High rpm high speed towing will probably burn a little oil and may be normal. If that is not the case I would be concern about the relatively poor mileage and oil consumption.
On 12/15/2021 at 3:55 PM, customboss said:
Fuels dilute of the engine oil is THE player for engine oil usage if all else is normal.
Use a higher quality  oil, change out the air filter more often if you are dusty down there in Corpus.
If you want to KNOW why,  take a oil sample using a good quality lab with GC fuels and FTIR  testing you'll know for sure whats going on.
If you have never changed the air filter on that 6.6 yet that may be allowing too much fuels dilute of the oil by restricting air flow. ECM can only go so far to correct.
I use mobile 1 5w-30 full syn. I always thought this was a good high quality oil. It sure is expensive enough! As far as the air filter, at 7K I installed a K&N intake. mainly cause I like the sound, I don't put much stock in HP gains. Would this have an effect by allowing too much air?
I do my own maintenance so I can guarantee it had 8 qts. Even my 2015 5.3L took 8 qts so this is not a mistake I would have made but thanks for the input. I sincerely appreciate everyone taking the time to give me your thoughts.
Too much intake air flow not an issue, nor is Mobil 1 5w30.  What happens with K&N oiled air filter media is it loads and restricts airflow. That forces ECM to try to counter the restricted airflow. Another issue I have seen in testing is that oiled air filter media if not serviced perfectly can allow dirt ingress in micro tears of the cotton media.  You may be over-fueling needlessly because of that intake system unless its in perfect condition and serviced frequently.
Edited by customboss
oiled not oil
I don't consider myself to be towing "aggressively" but I do travel at the posted speed limits when applicable. Here in TX alot of the highway speed is 75mph. When I set the cruise control, I get a lot of shifting when going over small overpasses so I tend to lock out the 2 overdrive gears which leave me at around 3k rpms. I figured that puts me closer to the powerband and with a gas engine I didn't think this would hurt anything. Thus my mileage can be pretty crappy.
On 12/15/2021 at 3:38 PM, Grumpy Bear said:
Something didn't sound right. A quart in 100 gallons is .25% Sounds like they have a reasonable target for the application.
If you use a 2 quarts in 750 gallons that is only 0.07% Not much more than a modern passenger car. (I used the wrong units earlier) towing will make this number higher
Sorry I was still on my first cuppa coffee 😉
I've always used .03% to .05% per gallon of fuel as normal. Way I was taught.
https://www.ms-motorservice.com/en/technipedia/post/when-is-an-engine-consuming-too-much-oil/
[quote] Workshop manuals and operating instructions often provide information on the maximum permitted oil consumption for the engine. If the manufacturer's specification is not available, max. 0.25 to 0.3 % for utility vehicles and up to 0.5 % oil consumption for buses can be assumed.
Oil consumption in modern passenger car engines is usually less than 0.05 %; the maximum permissible oil consumption
stands at 0.5 % (all percentage values relate to actual fuel consumption). [end quote]
GM in the light trucks and cars will not warranty work until consumption is a quart in 2,000 miles. In the case of a vehicle that is getting 25 mpg that is 1.2% or 240% of the industry maximum standard and 2400% over what most people experience normally. The fact they have this in writing at .25% is not normal for this company and even generous.
Sounds like you don't have an issue...
Great info!!! This puts my mind at ease and I appreciate you taking the time to explain it.
Agreed south texas not a demanding environment for engines or towing unless its really hot outside.
Most of the oil bath K&N and Amsoil filters I used in my 1/2 tons or pulling rigs had flow indicators. I never had a problem. Of course it’s probably been 10 years since the last one. With the exception of my 383 blown 92 Chevy with 12LBs of boost. That I had for 12 years. I guess that’s just another reason you wouldn’t see my in a newer truck. There’re just too sensitive.
This is very new to me so I will be doing lots of reading!!!
Direct injections engines definitely have carbon issues on the intake valves. I have seen it on other brands. If it were me, I would use a catch-can or maybe even 2 of them, to reduce the likelihood of the carbon issue.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,978 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
