Is it normal for the truck to shut off engine after 10-15 minutes whenever you use the auto start remote? Or is the truck suppose to stay on as if you had the key in the ignition? Mine would allow maybe 1 or 2 times of remote auto start, after the 10-15 minutes it shuts off, then if I still want to remote start again, it wouldn't. TIA!!!
10 minutes x 2 is completely normal. Your truck is working as it was designed.
  • Thanks 1
Where I'm at in Minnesota it's below zero a lot and even after 20 minutes it's still cold.
I wish it had a high idle setting when it's below zero.
10 minutes at 1300 rpm would be better than 20 minutes at 550-600 rpm
You can set a high idle with a handleheld tuner such as the intune3
  • Thanks 1
16 hours ago, rlcole321 said:
Throw on a jacket, run out, put the key in it, turn it on and run back in the house!
Then watch some low life drive it away . Unless you're out in the country I wouldn't do that.
    C. Hart
    C. Hart
  • Who's Online   5 Members, 0 Anonymous, 611 Guests (See full list)
