Is there any performance advantage to using higher octane fuel in GM’s 6.6 gas engine? There is in my Ford 2.7 eco boost so I’m curious about this engine. Haven’t been able to find the answer anywhere so far.
YES!
EDIT
Doing a search it requires 87 octane. Premium fuel would be a personal decision. It can't hurt anything but your wallet.
Edited by diyer2
4 minutes ago, diyer2 said:
YES!
Diyer2 - can you explain the basis for your answer?  Since the L8T is a relatively low compression engine, I was about to answer the opposite, but I have no actual test data.  Maybe you have experimented?
  • Thanks 1
Short answer is the 87 Octane will work best, unless you're in at high altitude, in which you'd run 85 Octane.   Places like Utah & Colorado will have 85 Octane.
Octane rating is a measurement of the ignition point of gasoline.  The higher the number, the more resistant to detonation (as in when the initial burn <oxidation> starts), but it doesn't change the amount of energy in the fuel.
That said, it is important to run quality fuel, and some stations sell fuel that barely meets the requirements.  So rather than go to a higher Octane, go to a higher quality gas station that has high traffic volume so the fuel you put in your truck is fresh, and of high quality.
Some great YouTube video, and complete explanations on the internet.
  • Thanks 1
Your Ecoboost likes premium due to the turbo compression.  The GM 6.6 can run great on regular.
Totally agree and understand. I was just curious since the eco boost is engineered to make more horsepower using premium fuel. For my 6.6 though.... 87 it is! Thanks.
2 hours ago, diyer2 said:
YES!
EDIT
And at today's prices it sure would hurt the wallet too. Thanks.... 87 it is.
Is your wallet a real concern when you already spent $60-70,000 though?
just sayin GIF
just sayin GIF
Not if I could get more HP.
On 3/23/2022 at 6:47 PM, MTU Alum said:
It was designed with fleet applications in mind so its calibrated for 87 octane.
#iworkforGM
The GM HD engineering crew knocked it out of the park with this truck! I haven't pulled with it yet, but I won't come close to maxing it out, so the gasser is perfect. Plus I can completely remove DEF and "limp mode" from my vocabulary.
Edited by HP4
  • Like 3
Good point.  I'm looking forward to see what the aftermarket will eventually come out with.  With the tightening of emissions standards, and GM locking down this ECM it is a pretty tough ask.  In another thread guys were hoping to see a supercharger.  Not sure that would work with heavy towing due to the amount of heat generated, but it would be pretty fun on the drive over to Home Deopt! :thumbs:
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
