Software Updates?
Just took my 2019 Custom with IOR 7" Stereo in for a problem with the radio, and the dealership told me I needed a "Software Update" and wanted $400 for it. Luckily the dearship that sold me the truck 2 months ago was kind enough to offer me reimbursement for this. But does this make sense? Why in the bloody Hell should we have to pay 400 dollars an hour for Software updates? And, how often in the future will I need more of these?
7 minutes ago, Ribrown said:
Software Updates?
Do you have updates turned on in your truck? 2) Is your truck connected to Wifi to receive the updates? 3) Is your truck out of warranty? The dealer should only charge you if it was out of warranty.
1 hour ago, Ribrown said:
Software Updates?
Not free once out of warranty.  They are covered under warranty if you bring it in for a problem and an update will fix it, otherwise at the dealer it costs to update.
Certain radios in these now have over the air update capability that can do it on its own.
Do they really update OTA though? The 21 Sierra I traded in had a 2020 version of the software installed on it. Anytime I told it to check for updates, it always said there wasnt any.
My 2020 1500 LT with IOS Infotainment System received an OTA update to U157.3.1 on 4/4/2022; I'm still under warranty. Cannot find what tweaks this update did.
I am having issues with the infotainment as it does not show in the DIC when switching channels. So If i have Waze on the radio display and switch up a channel. I cannot see in the DIC what channel. I was told there is an update so it trancends from radio to DIC. Works sometimes but mostly not. Hmm, have to see if i have over air updates turned on?????
I had checked the Head unit screen for updates a few weeks ago and it told me there we r e not any available at that time. But yes, truck is out of warranty by 2 weeks. F--- Me. I just think it's totally ubsurd that we should pay for stupid software updates. When there's an update available for my Windows computer, Microsoft dosent charge for it! But this crook dealership charged 400 bucks for this update and it literally took them less than an hour after diagnosing. Rip off
While I agree that $400 is too much, the windows comparison is not valid since there isn't a tech applying the update. If you take your computer to a repair shop and they have to apply an update you will be charged for the techs time.
I would ask for a good will update since you are only 2 weeks out of warranty.
Jay
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
