On 5/14/2022 at 6:15 PM, pepe48134 said:
1200 miles on the truck and today the yellow forward collision light is on and lane keep assist is unavailable.  I know this was a problem on earlier trucks but I thought there was a software update that fixed it. Anyone having this problem on a refreshed 2022 yet?
My refresh is just about to hit 2500 miles and the forward Collision light is on and the Lane keep is dead.
going into the dealer Wednesday. Also found there is a two inch hole in the passenger side wheel well.. It looks like a defect.
Open the fuse block and remove the #11 fuse. It's a 10 amp fuse (red one). Leave it out foe a few minutes and bend the spades slightly to make better contact. The truck should be off. Try that, in most cases, it's been the fuse. I took mine to the dealer and they outright lied about it, which was verified by GM and Onstar. I was a GM employee at the Arlington plant for 30 years, so I don't trust dealers much. Mine did the same thing the day after I got it back, so I pulled it myself and tightened the fit. I've not had an issue since and it's been over 2 weeks now.
Oh boy… here we go again…
3 weeks after the module swap, it happened again. Drove to a job site and left the truck running, came back and I had to start it again because it shuts off after 30 minutes… the light was on 🤔
pulled the fuse and bent the legs and it’s working again, hopefully bending the legs fixed it, @Kaylan Steen, I’m counting on you 😉
LOL... listen, I've not had an issue for nearly 2 months now. Fingers crossed!
Get out of here!!!! Two months??? Wow! I’m excited to see if it really works. Thanks!
Yep, and made a trip from Las Vegas to San Fran, and back without a hiccup. Went from 100 degree temps to 50s too. That says a lot right there!
This is certainly not what we like to hear, BigBadSierra.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your truck. To do so, please send an email to [email protected] with ATTN: BigBadSierra/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Add me to the list: 2022 Refresh AT4, early March built, delivered first week in May, have about 22xx trouble free miles and got the error yesterday leaving the boat ramp. Found you guy's forum and thread and tried the fuse trick. It cleared it for now. Gotta love the internet!
Bending the fuse legs didn’t work out for me… got the error again…962337BA-E7DB-4380-A8CE-0073A4D45A1E.thumb.jpeg.a6081d91bbafec52bd491fcfdf6e952b.jpeg
Did you bend them, or slightly twist? I did a slight twist so they're making tight connection on both sides. You can also try and put electrical grease on them as well. It's worth the the effort. I still haven't had issues since I've done mine.
Edited by Kaylan Steen
1 minute ago, Kaylan Steen said:
Did you bend them, or slightly twist? I did a slight twist so they're making tight connection on both sides. You can also try and put electrical grease on them as well. It's worth the the effort. I still have had issues since I've done mine.
Slight twist so they will make better contact… really a weird issue!!!
Well, if the mold that they used for the fuse block was off by a mm or so, it can happen. Especially, in colder climates, which make metal contract and some plastics. So, it makes sense to me. I won't be shocked to see a recall for a fix for it.
Thank you for the tip! I lost forward collision alert and adaptive cruise over the weekend at about 2400 miles. I pulled fuse 11 and gave the outboard tabs a little twist. Both features are working now.
My camera module gets so hot, I can't even touch it for more than a split second... So I ordered an NVME M.2 heatsink, I'll get it soon and see if this might be the issue as I live in the Phoenix area, and it's been 100F+ here every day for the past two months. I can't even imagine how hot the module gets when the truck sits outside for an hour and it's 115 degrees out!
Heatsink link:
https://www.amazon.com/gp/product/B0827PM9VR/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I live in Las Vegas, so I hear you about the heat. A few times this summer the temps said 120. That wasn't the actual temp, but that's the reading. The temps drop to the 70s at night, so that type of bounce isn't a positive if the tolerance in gaps aren't spot on. Let me know how the heat sink works. I've not had a single issue since I tweaked the fuse. Yes, I'm bragging. 😆
  • Haha 1
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 512 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
