Man has my DFM gotten bad.  Brought it to the dealer and they say it’s normal but it drives me nuts.  Transmission studdering, engine feels like it’s struggling, just garbage.
I have a 2020 elevation with the 5.3 and 10 speed just under 17,000 miles.  Putting it in L9 seems to make it so much better.
Is there a difference between running in L9 mode and installing a pulsar LT strictly for the DFM disable feature?  Is there any issues with running in L9 or with the pulsar LT full time all of the time?  Are there any issues with towing in L9 or with the pulsar LT?  Is it ok to run on the highway at high speed in L9 or with the pulsar LT?
it’s very depressing that I have to just accept having my $60,000 truck run like a beater POS 😔
Driving in L9 won’t hurt anything except your fuel mileage-it does disable DFM. The Pulsar will disable DFM as well but you will have all 10 speeds; you can also shut off auto stop, adjust throttle response and calibrate for bigger tire size. I have it on my Trailboss and highly recommend the Pulsar.
Another option worth looking into is the range afm/dfm disabler. I have that and it strictly disabled the afm/dfm. Quite a bit cheaper than the pulsar but uses the obd2 port. Would have to see if it works for yours as mine is the 5.3 with the 6 speed. So much better driving without that.
Our '21 has the 5.3 and the 8-speed and I always drive in L7 for normal driving to disable DFM. Our engine turns about 1900 RPM at 65 MPH in 7th gear (3.23 axle ratio) and it seems perfectly happy there. Running that speed in 7th with 89 octane gas and stock Michelin all season tires at 38 PSI, though with the air dam removed, I can average up to 23 MPG on a longer highway trip on flat-ish terrain, so no real fuel economy loss in that scenario, either.
When towing, I use L6 on the highway as that is the 1:1 gear in our transmission (your 1:1 gear is 7th gear in the 10-speed). Since we tow a camper with a fair amount of wind resistance, holding the engine at roughly 2000-2100 RPM at highway speed (65 MPH or less) is ideal to avoid lugging the engine or excessive hunting for gears. On extended up hill grades on the highway, I shift down one gear (L5) so it's closer to 2900 RPM. We get between 11-13 MPG towing our roughly 3700 lbs. 19 ft. camper on 89 octane. Don't forget to engage tow/haul mode, too.
I highly recommend the Pulsar. The ability to increase throttle sensitivity is worth the additional coin. The DFM and auto stop delete works as they say. I’ve only ran it for a week but I am sold!!!
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
