11 hours ago, Grumpy Bear said:
Limiting  HTHS loss is not always indicative of the oil not meeting the min film needed in your engine.
Mobil 1 uses formulations that BY DESIGN thin slightly so over drain period they stay
in grade because their polymers reattach over time. That’s the formulation plan.
On 9/24/2024 at 10:50 PM, Grumpy Bear said:
@customboss, no need for confusion. You of all people are aware that this is a dynamic situation that everyone tries to see as a static moment. Lots of moving parts that must be connected. Separating out a single point, a marketing trick, does not paint a complete picture. And you also surely understand the difficulty of explaining that dynamic.
What I see clearly in mind, words sometimes can't capture.
Try to explain to someone the nature of a rod bearings travels over time. How rotation reverses and what effect that has on the hydrodynamic wedge at the point of reversal. How the load at any given point along its arc effects the Hersey number. Make them understand a load plot and how GM defined and plotted that data stream during the development of the Gen 1 SBC. Even changing the forced lubrication point of entry based on that data.
Get them to understand the value of time in a wear study and how accelerated testing does not even come close to the reality of Joe Average's motors life cycle. And yet, is still useful. How personal observation over decades does not lead one to the truth in the absolute only to a better/worse conclusion that we will not live long enough to fully explore. They can't do it in a lab but some a certain that a lifetime of experience is absolute.
Ring tension hysteresis on film thickness at the reversal points and how those two points differ. Or how the oil temperature in the pan is not the point temperature anywhere in the motor other than the pan and its value is not the average nor even the median, just it's dynamic thermal equilibrium.
What we can say is what is directionally correct but without the certainty of the acceleration of gravity.
So, we chose points of discussion.  Stare so closely at the eye, that we can't tell if it is the eye of a human or a horse. We don't even share points of reference in these discussions.
One in concerned with wear mitigation and cleanliness and another's concern is warranty and fuel economy. :dunno:
A dog chasing its tail.
You a "part-time" philosopher???
  • Haha 1
That is the silliest thing I've ever heard. :crackup:
How on earth can they stay in grade by going out of grade. Exactly what we witnessed in the HPL video? Under what period of non-shear would they 'reattach' and by what mechanism?
I will agree to the line in green IF you have an excess to begin with and upon shear it does not exceed the MOFT.
Cheap is just cheap. It isn't a plan for success. Just one of margin. Did you bump you head today? 🫣
Checkout the API specs allowance for shear and permanent shear.
MOFT is much lower than recommended viscosity for manufacturer.
Ah, and there we have it. 🫣
That machine is mindless and uneducated. It responds to what is and cares not what we think it ought to care about. Viscosity keeps parts from touching other parts it shouldn't be touching. A first date thing. :crackup:It doesn't know who the API is or who the SAE is, and it certainly hasn't a clue who the ASTM is. When a chemical company starts telling me a flaw in the product is a 'feature' then :idiot: That story is pure SPIN.
I've been around the block long enough and had enough tuna cans opened up to know that what I SEE and MEASURE in light of what I KNOW its history is/was, is more relevant that the theory or calculations.
Quantum Entanglement and 'fuzzy logic' did not invalidate time space relativity.
I had a PhD tell me once that we could make a water born oil-based alkyd instead of alcohol/mineral solvents and keep in solution and it would still cure by the method of crosslinking. They told the team this because the NEEDED it to be true to solve the VOC issues of the coatings were selling. They BELEIVED a competitor had already done so based on a JOURNAL.
I'm the janitor on this team. Lab research rat and I KNEW oil and water do not and will not mix and remain in anything but an unstable emulsion for more than a short while. Throw as much dispersant as you please and all you get is a wet mess than never dries and will not spray. Well Eastman spent millions and years and all we got was fired for not doing the physically impossible. Hurrah, they still don't have a product other that a LATEX that is water born.  Sometimes smart people amaze me with thier stupidity.
I’ll be short on acronyms and testing data but I put 5w30 synthetic in my 5.3L yesterday and it seems quieter and smoother so far. No warning lights or new issues. The starts after auto-stop are much smoother and quieter.
@Gangly
Edited by AJMBLAZER
  • Thanks 3
@Gangly
Bought a new Mitsubishi Mirage that calls for 0W20. When I picked it up, I had the shop change oil to 5W30. These motors are OHC but shimless bucket solid lifter. They clatter a bit at idle. Even they were amazed at how it quieted it down. They told me it would ruin the fuel economy. Listed highway is 41 mpg. I get 57-63 so far and it is still breaking in. only 1700 miles so far. On tickets not on the DIC. Motors are happy when internals are not being drug across concrete. They told me it would void the warranty. I asked them about the full spectrum recommendations in the UK market then and how they would PROVE the viscosity did any damage. 🤨 They gave in. In the UK market everything is on the table in the manual from 0W20 to 20W50. Looky there, no OIL acronyms. Okay the W :crackup:
Edited by Grumpy Bear
Where have I been Grumps? You bought a new car?
Engine oil bench testing like HTHS that you reference above ON USED oil will look different than a polymer shredding test in a video with a clean formulation. HTHS, Kinematic and dynamic vis readings will change.  THE ENGINE test procedures allow vis loss both temporary and permanent  in your commentary  above shows you don't know what you are talking about as you mix bench testing with engine testing and back and forth.  My commentary about HTHS, Kinematic readings in used oil allows losses of certain %'s.   Mobil knows that and formulates to stay inside those boxes.
Having stated that the only lubricants that stay literally in design viscosity like new are GRP V versions.  Look at RLI in my L3B here.  For $3.5 qt that's some good value on a fully BIO synthetic!  I may eat it over 6000 miles at about a qt but it burns clean out my tailpipe!
I’ll acknowledge I think a little differently than some on here. Personally I believe actually recently I must admit. Two hundred thousand miles is about all I want to drive a vehicle that I drive on trips. One hundred and fifty thousand miles was the limit. The exception are 2002 to 2006 GM trucks and SUVs that I have experience with. They are basically bulletproof. The 5 vehicles I’m tracking currently an 05 Elantra, an 11 Genesis, a 15 CRV, a 16 Camry and a 17 Odyssey. My 02 Avalanche I didn’t acquire until 4 years ago. The rest I’ve tracked since new. The avalanche had completed detailed records. The Camry, CRV and Odyssey had 10K oil changes most of their service life. The Camry and CRV are still on that schedule. The CRV while I used it had a couple of 5K oil changes. The Odyssey up until 127K miles had 10K oil changes. I gave my daughter the CRV and took the Odyssey and dropped it down to 5K oil changes. Only for it having cylinder deactivation. The CRV is close to 100K miles. The avalanche leads with 184k. The Elantra, Odyssey and Genesis are 150K and over. The Camry on their heals. My point finally is they run factory recommended oil. Even 0-20 one semi synthetic. Prior to my retirement 15-25k oil changes was the rule on Amsoil. Engines are more complicated and less mileage driven. Increased my oil change intervals. Until I experience a reason I’m pretty satisfied with my current Valvoline quick service. Or the dealer. That’s my experience. Not real complicated, no stress. By 100K miles I certainly got my money’s worth. By 200K I’ve had enough I’m quite certain.
Then you aren't informed enough to comment on used oil testing for making engine oils. Read me above.
    • IMNTBHO;  the worst thing for the 6L80 is to be lugged down to low engine rpm while in high gear......AKA, to save fuel.   I rarely use D on my '16 with the 6L80 and use M mode to keep engine RPM above 1500 at the speed I'm driving, which is also benefiticial for the tranny because line pressure is kept up because the pump is actually turning a decent speed, and it's not always hunting to drop to the next gear to lower the engine RPM's.   Never above 30mph.............M3, maybe M4 if just driving thru a small NoDak town Never above 40mph............M4 Never above 50-55mph.............M5   This is way better for the tranny and the engine.........especially if AFM is still active.   262K miles on my OEM 6L80 as I type this.
    • If they had nuclear material for "11 nukes" we'd have seized it.    Our military has been rendered either too weak/dumb to seize it, or they don't have it. Your pick,K-nut. Because right now we're fighting over who gets to toll oil tankers in the strait.    I hope you're man enough to admit you've been taken for a ride when it's finished.
    • I hope you’re man enough to admit that you were wrong when it’s finished.
    • And you're obviously full of it too.  Apparently anything he does is perfect to you.  Don't you think this whole ordeal would have been better if he had maybe thought it all through first before bombing Iran at the request of his bffs in Israel, Saudi Arabia, and Qatar?  They are the ones that had the biggest issue with Iran.  Thus they have been pouring the platitudes and giving gifts/bribes to him.  Had he thought about the consequences of what would happen to the Strait before starting anything, we wouldn't have this issue.  Now he is stuck with no way out of this mess.  But you have your head stuck way deep in his rabbit hole to see anything else.  So no, I don't have TDS.  I see what he is.  The derangement is yours from no oxygen in the rabbit hole.
    • Bringing of the fact that every President has said the same thing. They can’t have nukes. I guess you missed that before epic fury they said they had enough product for 11 nukes and weren’t giving it up. That not political or polarizing. The opposition of that is and giving aid to the enemy. The mandate is decades old through many administrations. The difference is TDS.
