4 hours ago, Richard105 said:
I'm confused about which camera works for the 2024-25's. I have the older camera unit, but I just got the 2025 Yukon that shows nothing when I plug the cameras in. I assume this Backordered unit would work. https://www.shopchevyparts.com/gmc/2025/yukon-xl/electronics/2025-yukon-trailer-camera-transparent-view-requires-trg-camera-provisions-p-92334852.html?sort=2d&search_in_description=1&keywords=trailer camera
But, what camera is in this new unit? Is it the 85573256? don't want to buy a whole new kit if I can just change the camera with this one: https://www.amazon.com/dp/B0DGT4JHQY?ref=ppx_yo2ov_dt_b_fed_asin_title?
 85573256 is the most current camera that would be in the trailer camera kit inside the housing.  If you scroll up the thread you can see that the trailer camera opens up and you can swap out the camera.
On 1/28/2025 at 12:07 PM, Aircraft800 said:
Thanks again for all the help!
I just installed the correct camera for a 2025 into the old housing from my 2023.
85573256 OEM Camera for Chevy Silverado, GMC Sierra 2500, 3500
It now has a picture, but I’m struggling with calibrating. I towed it 5 to 6 miles, but it never finished. I checked old pictures to ensure I have the same camera angle, and it looks to be the same. I was trying to find the 2025 Camera setup instructions to see if the 35 deg angle or the measurements changed, but I was unable to find it online.
Here is my old setup with my 2023 truck with everything working, and the second is of the new camera with my 2025 truck working. I changed the angle slightly up since this photo so it just includes the bumper like my old photo, but it still won’t calibrate. I also read that I need to be on streets with both lines, but the road I tried to calibrate on only has a centerline. I’ll try again next week.
Old camera with 2023 truck
New camera with 2025 truck, no luck calibrating yet.
Can you post a link to the one you found on eBay? I ran into the same problem you did and got the wrong camera
I just tried to order one from chevroletpartsdirect.com and it went through until I got an email saying it's on backorder and they refunded the order.
It looked like there were a few options on eBay, even one that included a bracket that was listed at $70, exactly the same camera and throw the bracket away.
85573256 OEM Camera
Edited by Aircraft800
I have the same problem. Does the 85573256 camera work correctly? Really don’t want to buy if it doesn’t work.
  • 2 months later...
Hi everyone,
I just moved from a '21 AT4 3500 to a '25 Denali Ultimate and neither of my trailer cameras work.  Tried to order 85573256 from the GMC website.  I can add 85573256 to my cart but can't check out so i called my dealer.  They said there is a new part number on the parts diagram for the tailgate camera - 85813746.  Google doesn't show any results for this new part number yet.  Anyone know if 85813746 is a legit substitution and will it work as i replace the old cameras in my traier cam set up?  Thanks in advance!
Edited by smokeyburnout
4 minutes ago, smokeyburnout said:
Hi everyone,
85813746 replaces 85573256.  85813746 has stock.
thanks again for the info!  very helpful!
Just to follow up for anyone that might be interested - I picked up two 85813746 cameras to replace the older cameras that worked with my '21 truck.  The 85813746 work perfectly and are a replacement for 85573256.  This must be a really recent substitution because my 2025 has a 85573256 in the tailgate and it was built in late March.  thanks,
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
