54 minutes ago, newdude said:
Exactly.  The 0w40 is only to bandaid the passed engines and hope they survive the extended warranty period 😉
Boy, that's the truth!
As true as that 'hope' may be, the truth, it isn't.
Let's have a look see, eh?
Crank can fail if it is of non-spec machining clearances. Crank can fail from non-spec metallurgy. Let's look at the second first and the first last.
Metallurgy. Can't fail from being to hard or to smooth in any way viscosity is useful. But it can fail from being to SOFT and if that were true then NO OIL ON EARTH will save it for the next five minutes. Liquids void of gas are INCOMPRESSABLE an as such will take more load than ANY metal can sustain. It's how a hydrodynamic wedge is formed. Hydrodynamic pressure. Kind of in the name.
First thing last. Clearance is non-standard. Too tight? Viscosity won't help. Too loose? Now there is can be useful. but only if the bearing clearance is loose AND the side clearance is also loose. Guys put non-Ford rods in flatheads with narrow bearings, thus HUGE side clearances and maintain oil pressure with bearing clearance. Tis the difference between being an engine assembler and an engine BUILDER. A motor like that is truly viscosity sensitive 😉
We forget the softest thing in the rotating assembly is the bearing itself. And the goal of the 0W40 is to prevent 'wiping' that bearing which is where Stribeck comes into play. And kiddo's if it is true in that case it is true is ALL cases. No motor on earth that isn't pre-oiled on start up does not suffer 'dry start'. Worse in stop/start systems.
0W20 requires perfection every minute of every revolution. You have to have a handle on BOTH TRIBOLOGY and METALURGY to have any picture at all.
Edited by Grumpy Bear
My Corvette and ZL1 Camaro both had 0W-40 from the factory. I don't think it's the bandaid as you call it. It's what should have been in the trucks from the get-go. But, these trucks have been running the wrong weight for whatever miles are on them. The test they are doing should find the ones that are fixing to come apart and the ones that pass should be good to go especially with the big warranty. Had I known what I do now, I likely would have kept the 2023. But, I do like the fuel economy of the 3.0l Duramax.
The 0w20 isn't what is killing these bad 6.2s though, its machining and assembly that is.  I've seen plenty of high mileage 5.3s and 6.2s at work (150,000mi and up) that run 0w20 and have yet to be opened up for mechanical engine work.  There's a 208,000mi 5.3 in today right now as I type this.  No lifters done, no cam replaced, nothing.  Just 0w20 at whatever oil change interval the customer does.
I lean with bandaid through the engine warranty because if a truck on 0w40 has a 6.2 fail, the new engine goes back to running 0w20 again and not 0w40.  Hence, its GM hobbling the ones that pass along to get through that warranty period.
Exactly.My neighbor has a 2020 5.3 with 109,000 miles on it running 0W20 and changes the oil when the OLM tells him to change it,still running good and sounds good. No problems with it.
Edited by Silverado4x4
Ok, why aren't the Camaros built during the recall time with 6.2's not getting recalled or having issues? I say it's the oil. And GM is nuts to continue using 0w20.
On 6/22/2025 at 12:21 PM, PunchT37 said:
This thread was started on the cost of an oil change.
Welcome to internet forums.
Kinda like sitting around with a group having a coffee or a beer....
If the got the machining right, the 0W20 would be fine.
The new engines, that they know have the issue corrected, are supposed to run 0W20
Maybe they know the plant with the machining issue(s) didn't produce parts for the engines assembled for Camaro?
Iv’e had tons of beer and coffee. Ain’t quit yet. 😉
  • Haha 1
Camaro and Corvette LT1 originally ran 5w30 Dexos 1 oil.  2014-2018 for Corvette, 2016-2018 for Camaro.
0w40 came to the LT1 engine for 2019 for track use requirements.  Prior to 2019, GM wanted the oil changed for track use in the LT1 to 15w50.  15w50 however had to be drained as soon as possible and replaced with 5w30 to prevent catalyst damage (all engines will use some degree of oil when driven very hard i.e. track days).
Starting for 2019, GM made 0w40 the standard oil BUT, its was Dexos 2 spec which is low sulphated ash content oils for gas and light diesel.  Low SAPS in gas engines started out in Europe with the advent of gasoline particulate filters (GPFs) which can not get loaded with ash or they will be rendered ineffective and damaged with a higher SAPS oil like a Dexos 1 (at the time).  0w40 Dexos 2 (now Dexos R) allowed one type of oil to be used in the LT1 (and LT4) for street AND track driven cars all while protecting catalyst life over the life of the vehicle.
So that is the only reason 0w40 came aboard in those cars.  Street and track use all under one oil umbrella that would maintain catalyst efficiency and not require special track use oils.  The only exception to this was the 2019 ZR1 with the LT5.  The LT2 in the 2020-current Stingray and eRay is the same thing, 0w40 for both street and track.  LT6 and LT7 (Z06 and ZR1) due to their engine design use 5w50 for both street and track.
0w20 in the trucks?  Simple.  CAFE.  Corporate Average Fuel Economy.  Reduce friction when and where possible.  That's why the gear oils went down to 75w85 as well.  All to eek out MPGs while still delivering a usable product.
Also one more important factor.  They build A LOT more trucks than they do Camaro and Corvette too, hence the need for fuel economy driven choices for oils.
  • Thanks 1
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 1,916 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
