On 8/15/2025 at 8:23 AM, diyer2 said:
If you believe in god thats your right. But the pushing of this belief on others is what I disagree with. You live in your world and let me live in mine.
If you are addressing this comment to me, nobody is pushing you.
Think of me as the guy standing on the side of the road trying to wave you down because the bridge is out in front of you.  You can stop and head my warning or keep going.
  • Haha 1
38 minutes ago, swathdiver said:
This is nonsensical thinking man.  Just as crazy as saying nothing exploded and created everything and that the law of entropy doesn't apply to creation.  Man loves darkness more than light.
False. Nonsensical thinking is believing Sky Daddy gave up his weekend for your "sins" and now you owe it something which it doesn't deserve. But it will apparently smite you if you don't give it up. Huh.
I can't make this stuff up...people really believe this.
  • Thanks 1
  • Haha 1
On 8/15/2025 at 4:20 AM, garagerog said:
Didn't matter, Harris said she wouldn't do anything different than Biden, on the foreign policy front either one of them had me scared shytless that nukes would be flying in the middle east that could lead to world wide conflict if either one of them had been elected. For an ex-military man your lack of acumen outside of your mountaintop bubble is truly amazing.
Yeah but what the hell just happened yesterday? Clapping, gifts, red carpets, and what kinda looked like a car beej. Must have sucked because lunch was cancelled after that.
Played like a Playskool Xylophone. Bing bong boop.
Edited by Atlas
  • Thanks 1
Totally shameful by any measure.  The POTUS is totally outclassed and out smarted by the commie POS creeper. Our WWII vets are spinning at turbine speeds in their graves.
James, I applaud your reasonableness, but sir, the problem with rational ideas are they are only accepted by rational people. 2 Corinthians 2:3,4 (You will understand the reference.)
As well meaning and as on point at the above comment is (wish I had thought of it)... Might I suggest Prov 26:4? :)
Now about them Cubs! Nine games behind. A bit late for the "June Swoon). 😬
  • Thanks 1
  • Haha 1
You're right txab, think I'll mosey on.
  • Haha 1
  • 3 weeks later...
To put a period on this thread. I heard rather briefly that George Strait put on a benefit concert for flood victims. The money was handed directly to the most affected with 65k checks. I learned strangely enough from the fat electrician on YouTube. That HEB  provides emergency relief during  natural disasters in Texas. Pretty impressive. The guys a blast, but for the language.
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 590 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
