What's up with the tranny already??
I was at a stop light today.  When the light turned green I gave it gas and the truck just stood there.  I took my foot off the gas pedal then gunned it again and it moved just fine.  Did it just that once no more problems the rest of the day.  Any ideas what would be the problem?   Truck only has 19,600 miles on it.  Thanks in advance   ???
Mine did that in my HD and I took it to the dealer.  It was doing it about once a day and both the dealer and the tech had it do it to them too.
They found a reprogram for the tranny and downloaded it to my truck and it hasn't done it since.
I have about 4400 miles on my truck and the reprogramming was done about 1000-1500 miles ago!!!
Thanks Shanners. I've only noticed it this one time.  I'll drive it for a couple of more weeks and see if it does it again.  If it does I'll take it to the dealer.
It's kind of a weird feeling, like you are in neutral and then pull it down into drive...  usually that was the way mine was.  The truck would free rev and then slam into gear, but there was some instances where the truck felt like it was starting in 2nd and then would drop into first once it started to roll...
  • 1 month later...
Truck did it again today, after starting it up and then putting it in reverse it just stood there. I had to put it back in park then in reverse again before it moved.
It's going in on Tuesday for the ext cabs windows making noises on the highway.  I'm going to ask them to check out the transmission.  This is one of those times that I'm considering the extended warranty.  :D
Mine has doen this about 8 times in 26K miles.  Hasnt done it in quite awhile (knock on wood).  I have discussed this with a few people and it sounds like a new valve body may be the solution.
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
