My 2017 Silverado has the typical touchscreen radio.  Noticed after changing my battery recently my radio has started operating on its own.  I can turn it on and set my channel and then i hear the touch tones and it will change channels or go to maps or other screens on its own.  Ive tried totally resetting to factory settings and that lasted about a day and it still continues to change channels or got to different screens on its own. Ive recalibrated the touch screen several times to no avail.  Has anyone had this same issue?
Have you tried removing the radio fuse & reinstalling it?
I had a similar issue.  Software update did nothing.  There is something like a "video display module" that needed replacing to fix the problem. $600 to fix at the dealership
Just now, Billhudson308 said:
Yes, I had a service appointment today; the advisor told me that the technician found that the display needs replacement. They will call and schedule an installation appointment when they receive the new unit. I thought it was the IO5 HMI module itself or wire connection. They tried updates for the HMI, to no avail.  It must be something physically wrong with the touch screen display. I’ve seen YouTube videos that show touching the “blue” button on the mirror and another that shows pulling the 20 amp radio fuse, wait 10 seconds and re-insert the fuse to reset the radio. Search YouTube for that. It didn’t work in my case. Good Luck.
Exactly what mine was doing the time it was replaced prior to this service request. Clicking behind the unit, jumping around, starting Pandora by itself, etc. I will let you all know what the technician did to rectify this repeated problem. I had to sign-off on a $150 diagnostic fee, but the advisor will reimburse that after the repair is completed.
how many miles are you at??
Does your screen in the middle of the cluster change on its own also? Mine goes from Info to radio. Touch screen also changes to various screens and jumps around when on navigation.
 Started at 74,000 miles.
Dealer wants to change the HMI @ $1100
Yes, and what’s really bad is the screen continually flashes from settings - to radio - to media - to settings, etc. And it clicks with every screen change AND   it flashes the cluster screen which is known as the DI (Driver Information Screen). I have a case number assigned by GM Customer Assistance and I’m currently waiting for a return contact call from a senior advisor. I will update after the call back. An advisor by the name of Jose wrote that they will contact me in 24-48 hours. We’ll see if this is true. Stay tuned. Please.
Edited by Billhudson308
I am loosing confidance in GM's future brand, no way will i purchase the next generation truck or EV's from them. they cant make techy stuff reliable.. maybe GM needs to downgrade everything to less technology. whats the point of this crap , just make the base model worktruck reliable and simple..
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
