Went for an oil change the other day i have 76,00 on my 2005 Tahoe and they recomend that I change my differential fluids and replace with new. Now I know about doing the tranni especially since I tow a boat but never thought about differentials needed to be changed just make sure there full????
Yeah, it would be a good idea since you tow and it is probably the stock fluid in there. There is gonna be alot of metal shavings if it has never been changed.
Don't the lockers use a special fluid???
No, you do not need any additves with the locker (G80). The additive is for limited slip units which are not in the trucks. Synthetic 75w-90 as per owners manual.
+1 on that, I added the "additive" anyway, could not hurt.
Some additives can "hurt". That's why they say not to use them......
No, you do not need any additves with the locker (G80). The additive is for limited slip units which are not in the trucks. Synthetic 75w-90 as per owners manual. +1 on that, I added the "additive" anyway, could not hurt. Some additives can "hurt". That's why they say not to use them......
I should have been more specific as to what additive I used, it was the small GM additive that is used in vehicles with LSD. I purchased it from the dealer, and told them what vehicle I was adding it to, and what options were on the vehicle (in this case G80).
The G80 is not an limited-slip differential and does not need the additive. It's been discussed here under multiple threads. They also use the RPO code G80 in some of the cars (previous gen Camaro is one of them I believe) for their rear axle. So unless you specified that the G80 was for a truck and not a car, they might have assumed it was for the LSD in a car, which needs the additive.
Please correct me if I'm wrong.
Sounds right to me, no additives needed for G80 because as stated it is not a limited slip, it is a gov-lock. I try to change diffs and transfer case fluid every 25000. I think factory reccomends every 30000.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
