I love my truck!
So my truck is nothing special... K&N intake and a Magnaflow muffler in the stock pipe, 3.73 with a G 80 (Soon to be tuned in Amherst) but today some kid in a Civic with a fart can and 500 stickers lined up with me at a stop light. And the old Silverado taught him a lesson... I know its not that big of a deal, but man did it feel good to smoke that stupid little car and show that kid what a real vehicle is.
yea i do that around here a lot. a lot of rich kids with daddys money get trucks, but some love the hondas and with the money saved buying said honda they splurge at autozone for it
^^^^^ lining up with cars and racing on the street, smoking Honda Civics :crackup:
LOL......Won't be long, he'll be back here complaining about another speeding citation he got :nopity:
. :dupe:
. :dupe:
Bwahahaha
:popcorn:
Nah.... I got burned out on it. Plus 1 more ticket suspends my license. So now I do the limit +/- 5 mph
What kind pf tune are you getting? Thinking of getting mine tuned too. Live in CT
I will be going blackbear if possible. I need to get in before the event fills is the problem
You can always go the AutoCal route if you can't get in.....BlackBear are definately the people to deal with if you are wanting a custom tune.
With the AutoCal, do I need to have the EFIlive cable?
I would love to organize a group buy in central US. I am in Oklahoma and I know I would be willing to drive to Texas.
You should see there face when a 6600lb 3/4ton truck whoops the newer mustang
Tuned 8.1 all the way...
Sharp truck ya got there :drool:
a 5.3 in a RCLB will be pretty fast, thats a small truck. good feeling beating some kid in a 93 civic who thinks his civic is faster then a porsche 911
How about Kansas? :lol:
i dont think he has a long bed. but a tune will def wake up your 5.3. it did mine
Yeah I would any surrounding state
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
