gmc sierra denali all time 4x4?
Yes. No low range. It can also be had in 2WD of course. The HD versions get normal 4WD
The Borg Warner?(BW) model?4485, RPO?NR3 transfer case is a 1-speed, full time, all wheel drive?(AWD), transfer case. The transfer case provides power to both axles, through an external planetary type differential, which has 2?different sets of pinion gears. The planetary differential provides a 40/60?torque split, front/rear, full time. This means both axles are constantly being driven for maximum traction in all conditions.
The transfer case external type planetary differential functions the same as a typical rear axle differential. The transfer case differential pinion gears function as the spider gears, and the sun gears function as the side gears.
The following actions occur because of the planetary differential:
If the vehicle is on a hoist, the front propeller shaft can be rotated by hand.
The vehicle cannot be driven if 1?propeller shaft is removed.
Operating the vehicle on the hoist can damage the differential pinion gears, by over-spinning.
Operating the vehicle with 1?propeller shaft removed causes over-spinning of the differential pinion gears.
The BW?4485 design of the planetary differential allows the use with the Vehicle Stability Enhancement System?(VSES) vehicles. The VSES takes use of the planetary differential, by applying braking to a tire that has less traction and dividing the engine torque to the other axle.
The BW?4485 case halves are high-pressure, die-cast magnesium. Ball bearings support the input shaft, the front output shaft, and the rear output shaft. The transfer case requires DEXRON®VI Automatic Transmission Fluid?(ATF) GM?P/N?88861003 (Canadian?P/N?88861004), which is red in color.
Tks a lot buddy...
Regards
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
