Chicken fried steak, biscuits, and gravy is better
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Mind numbing all day safety course. I'd slit my wrists but apparently razor knives are not allowed on site, only blunt scissors and safety cutting tools. :lol:
Mike, I have a spoon that I sharpened. Want it?
Edited by chawkins6789
Survived that only to come back to the hotel with another awful chore. It seems the way I've been logging mileage since March is not how my employer wants it so now I get to re enter all of it.
Did some running around. Looking for a poker table.
Speaking of brakes.. I have drilled/slotted rotors on my sierra hd and when your into the pedal a little harder then normal there is a little shake in the truck and steering wheel. Can i have these rotors cut to have them true and without any waro if there is any.. I really didnt want to have to start fresh with new rotors.. New good pads all around is a definite, I also thought about fresh calipers all around because the one rear hangs up slightly if you set the E brake and release it.
I don't think you can cut the drilled rotors. And the ebrake hanging has nothing to do with the caliper, separate system unless the big trucks are different than the 1500s.
March and April mileage reports done. Then had dinner. Still gotta get through October. Not happening tonight. :lol:
Just got home from Georgia where I was stationed for work. After 4 months there driving a new 5.0L F150, I drove my 5.3 Silverado today for the first time in forever and it feels like a slug!!
Would really hate to have to buy a Ford, hope the 2014 GM truck engines reallyare what people are talking them up to be or I may have to go to the dark side. At least I have a V-Max to drive also, still feels pretty quick.
Edited by BlackZ71Silverado
Double post
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
Edited by zach1990
Removed the camo and put my old wheels back on. Just waiting on my 3" blocks to come in tomorrow
Car got washed and a coat of wax. Time for hibernation?
Truck gets sealed and waxed Thurs/Fri
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
