I went to Topanga Canyon Mall last night in the truck. Had to exchange and figure out a new gift for my God Son and pick up a gift for my mother. I probably ran over 6 or 7 Priuses fighting for parking spaces.
TPMS came back to life today. I had got it recalibrated but it went out again, so I aired every tire up to 50 to try again. I never calibrated it and it set like that for 4 days. I start it up today and everything worked and gave me pressure warnings. Weird.
Been all over lately. Spent the week before Christmas working at a customer site in Ohio. Drove my truck instead of getting a rental so I could leave from there to go to NH. Spent the week at my parents at working the non-holiday days in the office and drove back starting yesterday. What made my day on the way back today was I passed a car hauler just outside Cleveland with a bunch of new 1500s including one in that incredible metallic green so that is still a special order option it seems!
Well yesterday I got stuck... in my friends driveway, how embarrassing. I still don't have 4wd cause of my front differential making noises so that's my excuse.
Oh yeah, I had to get pulled out by a Ford :/
Sent from the side of the road...
temp changes affect batterys
Sent from my SCH-I535 using Tapatalk
That part of the weirdness. 55 degrees when it dies. 35 when it came back.
Need to change my oil. Its at 71% life remaining after 7 months.
Also, if I sold the Tahoe now, I could pay off my house. Or keep saving/paying mortgage payments until fall and keep it.
Car wash today down here in western MA....last day of Christmas / family vacation. Can't wait for sub zero temperatures in 2 days, brrrrrrrrr
Took her out for a trip to have dinner and hit the grocery store. She'll probably get some serious road time late this week when we get hit with a round of snow.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
