Can't cross parts numbers cause the sticker is ripped off the new one. I can't see it being any different unless it blows up on me. Which would probably total the truck
You will likely be fine. Not like you have a tuned and modified motor pushing 500hp
Yet... lol sike I can't keep this thing on the road haha
I got a horrendous load of bear bait today with my 1500 and a trailer. It was 12 barrels, 4 cherries and 8 chocolate candy barrels. The cherries were very heavy, the chocolate moderately heavy. I just drove about 10 miles home and will reduce the load before I drive North.
It's hard to set up a time with the candy factory, so I just wanted to get them home for later. In the past I got as much as 16 barrels in one load with my previous 2500 HD, trailer included. The truck handled the load pretty good, but I wouldn't want to stress the trailer on a longer tow. Of course I had to make sure the 'bait' was fit for bruin consumption, tasted great.
Picked my truck up from the dealer last night after haveing new carrier bearings and all new seals put in my rear end. ...
Sounds kinky! Did it have a happy ending? lol
I love tapped my bumper on a stucco wall this morning as I was backing out of my parking spot. It was very gentle and it only left a minor scuff on the left corner of the plastic.
And based off of 14 gallons of 91 octane in 146 miles or so I am getting 10 mpg. 50 miles of that were highway and the rest was on the street. Luckily those 14 gallons have been lasting me just about two weeks lately, not bad.
Lol my jumping days are over with the truck I need a beater.
sent from my truck in a field
I did i got my truck back in time for the long weekend. :thumbs:
Why the picture of the shift panel? I'm sure I missed whatever it's about.
She's been working her 4wd for a few days now. It wasn't working.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
