You still looking into that owner/operator hauling stuff?
Got a job opportunity hauling RVs
I've had my auto zone Duralast gold battery coming up on 4 years now in December. Still strong!
Sent while in 'Murica...
The Yota just crossed the 6 year mark on its original battery. The terminals look like they are covered in moss. I keep saying I'll clean it properly when the battery dies(my 6's lasted 4 1/2 years), but it just won't. Probably do it this week. I think I'll just replace it before winter preemptively. Edited by SnakeEyes
Dad has a Four Seasons brand in his 99. It's been in there since he bought the truck in 2001. Still works. Idk how though lol!
Scared myself, been on a road trip last two weeks. First time on this trip and only the second time ever the low fuel light came on! I checked gas buddy and found a place with cheap fuel so off I go. When I left hotel it said I had used 32.7 gallons from my 36 gallon tank went about 10 miles to the closest station sweating bullits the whole way put 34.5 gallons into the tank never ever going to do that again!!
Drove mine to work. Have a squeak in my new leaf springs on the drivers side. I'll have to fix that at some point.
Do you have the regular rubber bushings or polyurethane bushings? The polyurethane ones have a special grease to prevent them from squeaking. Found that out the hard way, had to uninstall the springs and press the bushings back out to put the grease in there. No more squeak now!
Changed out the NGK TR5 V-Power spark plugs on the 2002 Silverado today. The plugs had 40k on them, truck miles are 148K. They still looked good but I had a set of AC Delco Iridiums on the shelf so I put them in. Now I should be good for at least 100k miles.
I went a little crazy with the anti-seize on the last install. I didn't put that much on this time. I have to say they came out really easy. :lol:
2002Silveradosparkplugs006_zps2103277c.j
2002Silveradosparkplugs005_zps8ee9f764.j
2002Silveradosparkplugs001_zps0beafd07.j
2002Silveradosparkplugs002_zpsf6de6c45.j
Tore the carpet out of the Triton. Kinda semi restoring it. New seat skins, carpet, fortrex 112 trolling motor, 2 power pole blades, control and cables.
No idea lol!
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
