Truck cruised good at 90 mph :) was getting 12 mpg
Ryan
I getting ready to cruise in mine tomorrow afternoon going to go about 900 miles before I stop!! I'm looking forward to the next two weeks!! More than likely will not be on to much, I'll try and post some pictures every once in a while. :jester:
Zach, I forgot what a guy sell your truck and the fuel pump goes out!!!! At least you helped him change it out!!
I didn't sell it lol. Gave it to my little brother for his first truck. He loves it. Already got all the bells and whistles a teenager wants
I know i have to either pull the bed or drop tank to change the left leaf pack i believe
Cut the non threaded part of the bolt off and it will come out easier, if i recall corectly.
I wasnt really wanting to buy new bolts though
Where ya going? Have a safe trip
Ryan
Dont need to. If i remember it had a big long hex shaped portion before the threads started. You can cut that end off and still reuse it? Unless they changed from what i remember. The one i remember was a 2000 though?
I passed through ryans area! Bored at a hotel in peru, in. Got a sweeper maintence and troubleshooting class tomorrow. Yay! Lol [emoji15] [emoji379]
The leaf spring bolt goes in from the gas tank side so it has to be moved anyways.
Source: I've done it too many damn times lol
drove a bunch easter weekend. Bugs are out almost in full force :(
Bugs ... holy crap ... we still have patches of several-inch deep snow, and 2' deep plowed piles left here ... :nonod: Not melting fast enough ....
Hit 56F (not doing the degree symbol again - hit ALT 017 ... and before I could hit 6, I lost my post and the page disappeared! WTF ..) here today. Nice, but I'd rather another 30 degrees ...
Threw an exhaust on a '11 Silverado today - junk Flowmaster totally rotted out. Then my simple bolt-on-and-go plan turned into an hour of fabrication, since the last guy hacked off the flange and welded a pipe in place. 3rd exhaust job this week!! Been a brutal winter here ...
I ordered the Belltech Street Performance shocks and picked up some leaf springs today
Edited by Chris
Got them 37's mounted today!
Meh trim and throw some 40s on. Lol. Looks great bud!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
