706,029 - rear tires pulled, still just under 6/32nds left. Replaced with 265/75/16 Bridgestone Duravis R500 14/32nds, full tread. Plan to go switch to 235/80/17s Michelin ATs after it snows.
Control. 235s are just as tall as 265s. Just 1.5 inches narrower. In snow and ice even if the tires spin they stay under truck. Wide size tend to wonder / float. Narrow cut right through.
Edited by Chevor
Yep - most people wouldn't believe a Model T would go through terrain in 2wd that would get any modern 4wd stuck. All due to the super skinny tires.
When they first came out, there were few paved roads - they had to be more of an ATV than a car in those days.
Yup, the winters going on my 91 are 235/85r16's they are about the same size as the 275/65r18s I'm running in the summer (within a .5")…
Now I want to see what the other half of warning sticker says.
Edited by Chevor
Only one station pheasible for me to go to with e85 and last I went the pump was out of order, still is as of a month later [emoji58]
My area: E85 is usually only pennies cheaper, maybe 20 cents on a good day, rarely more, so no one buys it here, so they don't bring more, so it will never be worth it cost wise.
Edited by SnakeEyes
Power>cost.
Except for me between the cost difference of 93 I get the benefit of more power and less cost that is called a WIN - WIN
My truck loses power in direct proportion to how much ethanol is in the fuel.
There was a guy on the first gen site that converted his complete system to E85 friendly, and even adjusted everything to work on it to the point he couldn't run regular gas, if so remember correctly. After a while he tore down parts of the system to see how it was going, and three was a green build up starting in the lines, carb, and some other components. He kept running it for the gains, he wasn't seeing issues, but we were wondering how it would turn out long term.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
