Where'd ya get a gm trucks banner?
I think someone may be a little jealous... lmao!
More than a little
Went to wal-mart for random stuff. Then harbor freight so I could pick up another set of 6 ton jack stands since they were on sale and 25% off coupon brought them down to what I bought the first set for. Now I can make the beast float! Found the receipt for the 4 ton HF jack, next month will be 5 years it's been lifting our trucks. Cheap crap indeed....
Watch out your gonna hit a stick.
Pulled the truck into the garage to check the wheelbearing. Nothing wrong there, nice and tight. Cranked on the brake line bolt some more, bled the brakes again, and rerouted the ABS sensor wire to give more slack. Hoping the noise I'm hearing goes away now.
Edited by Daryl Z71
Front airbag sensor:
Autozone $89.00 + tax. Amazon $61 + $8 shipping and 'handling' + $3.81 tax (Illegal alien welfare service) .For a part that likely cost ~ $6.00 to manufacture.
(Oh, that's the 'less expensive' Dorman part. So, in China, about $1.10 to produce)
Yeah! Lets gouge the livin' hell out 'em because, after all, even with seat belts, --thanks to insurance corporation hirelings our busybody, invasive lawmakers -- they can't pass inspection with that airbag light on. BWAHAHAHA!!!
Bought a lot of Sylvania Zevo lights. The 2 main bulbs and back up bulbs in the tail lights, and the amber 3157 and DRL.
Edited by Chris
Yep - welcome to MA! Land of 10,000 laws, and even more taxes ... :throwup:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
