Changed my transfer case fluid.
Edited by Daryl Z71
Hosed out between my fenders and bed after the winter. Just trying to make it last as long as possible.
So it's modded? Or is the next stage the final 7 HP.(rated 707 HP). If you want to cringe, look up how fast people have killed them(hint, double digit minutes after purchase)
He has 700 unlocked but I guess there's even more at 1500 miles or maybe opens up different race options. Either way that things fun.
Sent from my SM-G925V using Tapatalk
It is only rated at 707, so it is either all out or they keep the last 7 hidden. Next gain my guess would be a smaller blower pulley
Red key black key that is the only difference in HP
Black key is like 500ish
Red key is the 707
You dont gain HP out of the blue after a certain milage
Red key is the 707
Ok then everything I watched happen was all a lie. I watched him unlock 700 at 1000 miles.
758k
Pulling 30 ft camper. Ran through "Mile High" 4 AM. Downed to 3rd 45 mph through Eisenhower Tunnel and same over Vail Pass.
Edited by Chevor
Sitting back & watch as my house is getting packed up for the big move back to Alaska. Soooo happy to let the military take moving me this time.
Finally got off my butt and took out all the wheel weights that have been in there for a few weeks now. Had enough in there to bring the back end 1.5" at the center of the wheel well. After I eat I'm going to pull the clothes dryer out enough for me to get behind it and pull the panel off. It doesn't want to heat anymore, hopefully it's something simple like the thermal fuse.
Back north to the beautiful Alaska!
A couple days ago I had 5% Limo tint installed on the windows. It's actually not as dark from the inside as I thought it would be. Have been getting a lot of compliments.
Wow .. up here they call SWAT on you for windows that dark. You think I'm kidding ... :noway: You'll be surrounded by state troopers.
I think it's been close to 3 weeks since my truck last ran. Haven't even started it. Too much has gone on this past week to care about it. I figure if I don't drive it, I can't break it. :D
Was rolling this morning. I 15 S, South of I 70. 80 mph with a 30 foot camper. Road drops in in elevation from 7000ft to under 3000 ft in about a 120 mile stretch.
Had to downshift a gear few times to keep it from going faster.
Edited by Chevor
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
