Max life is the oil. Like the difference in castrol GTX and Edge. Max life is made for higher mileage engines. And i personally wouldn't go back and forth with synthetic
won't be going back and forth. Maxlife syn will just clean faster, if need to can go To Maxlife conventional And stay
Is it OK to go back n forth between synthetic and conventional if need be? And is valvoline max life an additive?
Edited by SnakeEyes
Going back and forth is no biggie.
Back in the early days of synthetic oil, it was a no no. In those days synthetic and dyno did not play nice together. Several people lost their shirts on engines figuring that one out. Like today, engines were not cheap, so word got around quick .. and that line of thinking still sticks 40 years later. Same as the "batteries on concrete kill them" myth - it was based on fact from days long since past.
batteries on concrete ? Haven't heard that one, please explain
As far as switching back and forth I would not, but to each his own. Just got paid so my truck will be getting an oil change. It's probably a thousand miles past due. She's sitting at 236k miles now !
Supposedly drains the battery, from what I've been told. I did it one time and didn't change anything
Seems to be more of a Northeastern thing, although it is spread around the country ... but WAAAAAAY back in the days of batteries with wood/tar cases, leaking / soaked-wood, electrolyte would in fact make contact with the ground (actually didn't matter whether it was concrete or not ... but since 95% of basements or garages are up here, the myth took off) and drain the battery.
With plastic cases it's nearly impossible, unless the thing is boiling over ... in which case you've got other problems to contend with. :D
Edited by Jsdirt
Over the weekend took a 3,000 km round trip to pick up a 1939 Studebaker Commander my friend bought. Truck pulled it Easy! Could barely tell a difference towing the empty trailer vs loaded.
Here's some pics.
20150411_170942_zpscuj9geit.jpg20150411_170904_zpsw6uignao.jpg20150411_170920_zpspgz8snln.jpg20150411_170832_zpseuusc3zk.jpg20150411_170252_zpsaqruwwms.jpg
Edited by maxco
  • Like 3
WOW what a friggin' BEAUTY, Maxco!! Love old iron - there's nothing better. :thumbs:
Congrats to your buddy on a excellent score! :cheers:
Thanks!! He actually also has a 1940 in his barn too that was his grandfather's but it needs a TON of work. This one needs really only interior, some wiring, lights etc...
Took it out to get a few supplies to hang some grab bars in our daughters bathroom. Of course while I was out it rained and so it is no longer nice and clean. :(
I need to wash her asap but its been windy lately so I might wait for it to calm down.
Otherwise nothing's been done.
Although where I'm sitting at work today has an awesome view..
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 1,372 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
