Scan Tool to read Air Bag DTC???
I have a 2005 Suburban. Have had the "service air bag" light come on and off over the last 12 months. I have done some reading and it appears the bag will not deploy with that fault code displayed. It sounds like the senor may be bad. I have a code reader but it does not read air bag faults. I think I need a scan tool. They seem pretty expensive looking at them online. I called Auto Zone and they have the same basic code reader I do.
What is the cheapest way to get the code read? Does anyone have advice on a scan tool that I could hook to my laptop that might read this code? I've seen a few for about $50 that comes with a cable and software. The senors are $107 each... if that is even the problem.
Thanks,
Daryl
Do you have the service manual to diagnose the code after reading it? There are numerous sensors for the air bag system. I have an OTC scan tool that reads air bag codes.
There are dozens of things that can set the airbag light from the sensors (there are three of those) to a loose connection. You need to search for a scan tool or software that can do more than OBDII codes.
Thank you for looking at my question. I need advice on reading the air bag fault code. A normal code reader won't offer the codes.
My real question was is there a cheap scan tool on the market to read the fault? I have a laptop I could use. I've seen a few that have a cable that hook a laptop but will these read the correct codes for an air bag fault.
Any advice would be greatly appreciated.
You need to read the descriptions of the software/tool. Some will do airbags and some can't.
  • 10 months later...
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
