Chit chat
SarahsGMC
  • Replies 9.5k
Haha! Wonder what's up with his Box?
His box kept me out of the box. If you understand
Got my FBI and DOJ fingerprinting done today
So, they finally caught you?
It is for my CCW. If i ever do anything they will catch me now
Yeah, I have had my done twice. Once for my job, second for my ccw
At least it was electronic
Got that pressure washer I was trying to get. Now if it breaks or I don't use it often $74 is easier to justify than $297. Worth the couple hours and trips it took. Driveway and house need to be blasted anyway.
Next thing to figure out is what oil and weight I want to use, it's been a year since the beast has had an oil change.
Had some visitors stop by the yard today ... :thumbs:
They mangled my feeder, lol. I'll have to ask my brother what brand that thing is (Christmas gift) - it took a beating! I had to straighten the hanger out - that was it! They bent the shepherd's hook all the way to the ground, lol. Had to straighten that back out too. The suet feeder is a lost cause - last I saw of that, it was in the bear's mouth, headed down the street.
They ate about 2 lbs. of seed in 15 minutes though those tiny feeder holes.
I tried to back my truck out and I didn't make it out of the spot before the right front started to sound worse than ever, I was barely able to pull back in. Hopefully the glass replacement guys don't mind too much, at least I tried to have the truck backed in to make it easy for them.
In FL, I'd run straight 30 or 40 weight in that. You can probably get away with 40 down there in the heat. I run Amsoil Formula 4-stroke Small Engine Oil in all my 4-stroke OPE: http://www.amsoil.com/shop/by-product/motor-oil/4-stroke/formula-4-stroke-10w-30-sae-30-small-engine-oil/?code=ASEQT-EA
Thanks for that, probably would have gotten around to asking what to run in the pressure washer eventually. Still need to unbox that thing. The Beast is my dually though. I've ran Mobil 1 10w-30 in my 6.0s. Haven't decided what to run in the Duramax yet.
In my Silverado, I went to 10w-30 Signature Series from 5w-30 - my oil analysis came back much improved with the heavier weight oil in there.
