I don't have a smartphone so I can't add pics too often but I have a 2001 Polaris Scrambler 500 4x4. When these things came out way back in the 90's, they were the fastest and sportiest 4x4 quads you could get. Not the fastest anymore but 60+ on a quad is fast enough for me most of the time. In the last couple of years, they updated it and now there's a 1000cc version. Had a 660 grizzly before that, wish I still had it. Never had a sport quad before but a couple friends had YFZ 450's and those things don't need any mods to be fast.
Here is my 13 Raptor 700R. Installed Pro tapers, moose nerf net and ASV levers.
post-129398-0-98652600-1396304588_thumb.jpgpost-129398-0-50070900-1396304595.jpgpost-129398-0-69745200-1396304605_thumb.jpg
Here is my 2003 Honda Rincon still going strong with 7,000 miles on.
Edited by craig1971
Nice! I used to own an 08. The torque of those things is amazing!
Sent from my Droid Ultra
Nice! I used to own an 08. The torque of those things is amazing! Sent from my Droid Ultra
Thanks! Super torque and does 75-80 on the highway too!! Looking to add a 1000cc can-am to my collection next!!
My Teryx Sport after I lowered the cage. It was a great machine and would go anywhere. But I sold it and kept my 03 650 Prairie because most of the trails weren't wide enough for the side by side.
'99 Kawasaki Bayou 220. Bought it new in August of '98, and it is used mostly just for hauling deer out of the woods. It has hauled out tons of deer, and one time 3 at once. One on the front and 2 on the rear. I like it's small size as it allows me to snake through the woods where the big machines cannot.
Other than normal maintenance and batteries, I have only had to clean out the carburetor one time over the years. I put an inline gas filter in it after that, and never a problem since. She is an oldie, but a goody.
Here are a couple shots of it when I was turkey scouting a few weeks back.
Edited by Ventilator
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
