Here is my 07 Grizzly 700 in action. Completely stock except wheels and tires. post-140150-0-02289300-1425067515_thumb.jpg
Edited by Ilivalidle
2013 Polaris RZR 800S, wifey loves it more then i do
Here's ours, '06 Suzuki LT-R450 & '07 Suzuki LTZ400...GOT SAND?
Nice! I had a 08 z400 special edition exactly like that and now have an 08 LTR450 special edition.. Don't ride to much anymore but I can't bring myself to let the LTR go
My 2012 Polaris Sportsman 400HO. 3,000 miles and runs as good as the day I bought it.
The 8120 in the background is not mine.
Here is my 07 Grizzly 700 in action. Completely stock except wheels and tires. attachicon.gifimage.jpg
That's some serious off roading..
Hey thanks! The Z is the wife's ride. They've both been great quads since new. Hard to get rid of them for something newer, considering there really isn't on the market I'm interested in, other than an overpriced RZR1000.
Those are paddle atv tires right? Very nice toys you have there.
Yes they are. We ride strictly sand dunes. There are several types of sand paddles, these are straight cut/lightweight type. Excellent for climbing steep dunes and sidehilling. Thanks for the comment.
After owning 7 Yamaha's (2 Warriors, 3 Banshees, 1 Kodiak, 1 Wolverine) I pick up my 1st Polaris tomorrow.
2014 Sportsman 850XP LE. Buying it 'used' but it only has 67 miles on it.
Edited by ~Wicked~
Nice Rims ... looks like the suspension kicks azz on that bike too ... good luck with it.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
