I looked at a RZR 570, they don't do anything for me, no interest. I prefer the Utilitarian advantages the ranger offers, no need for what the RZR offers.
If I stay atv, it will be a Grizzly 700, but if I want to sit, either Ace or Ranger.
I sat in an ace, and for being a heavier set guy (6' 2", 275 lbs) it was not very comfortable. Knees hit the steering wheel
  • 3 months later...
My sons Trx 250 and my youngest has a Tax 90 but I don't have a pic at the moment of the 90
I had a Honda 250ex growing up. That thing was bulletproof. Great quad. Can never go wrong with a Honda Quad.
  • 4 weeks later...
Here's my 2013 Raptor 700. Shes got a big 3 kit (DMC Force 4 Duals, Pro Comp K&N filter, PCV), 4 Hiper beadlock wheels with GBC XC master tires, KC lights 10" handlebar LED, GYTR nerf bars and heel guards, and PEP front shocks built by SFRacing. I'll post a better picture later of her all cleaned up.
In the bed off the tailgate, tires hit tailgate and won't close, no biggie.
2016 Polaris Sportsman 1000 High Lifter.
975 lbs.
No problem going down the road.
975 lbs.
Look at DG Tailgate Supports. They make different sizes allowing for the tailgate to be partially shut. I picked up a set of 10" ones to haul my Sportsman and they work great.
Front.jpgHere's mine with some finial Mods on my 2014 RZR XP 1000 with 36" Terminators on 18" wheels,
Oh my. I need this for my duck lease!! Nice! Edited by dasimmon
  • 2 months later...
  • 3 weeks later...
I just bought my 2001 Rancher 4x4 350ES. Needed something to help maintain the property, and this fit the bill perfectly.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
