Difficulty in refueling
My son has a 2008 Silverado 1500 and has recently been having problems refueling. He tells me that the fuel nozzle keeps shutting off as if the tank was full and does it even if he holds the trigger by hand. I told him to look for any obstruction in the fill pipe that may cause the fuel to back up the fill pipe and trip the nozzle to shut off. He says the only way he can fuel his truck is to hold the nozzle trigger at it's lowest dispensing rate. Anybody have this difficulty before or any ideas what the culprit could be? I thought maybe somebody tried siphoning fuel from his tank and maybe the hose fell down into the fill pipe???
Thanks for any ideas or suggestions.
Fuel tank evap cannister vent is plugged..
scooby
There is a screen at the bottom and the sending unit is usuallly in the way from siphoning.....
Dont mind me, just testing out the new 'Best answer' feature.
Yep, the tank vent is plugged. I know it isn't truck related but a friends Camry was doing the same thing. I got under the car and pulled the vent tube down and a bunch of mud from dirt dobers was inside the tube. Cleaned it all out and it was back to normal.
Mine was doing the same thing but seemed to fix itself, i think there was water that must have froze in the vent. I was also having starting issues too. Nothing major it just didnt start as nice.
Maybe pull the nozzle back some until it stays on, or try a different pump...some pump mechanisms are more sensitive than others.
Canister vent valve solenoid. Little black, say 3-4 inches tall cylinder with a connector and some hoses on it. 2010 and prior trucks there is a bulletin for re-routing the filter box for them by moving the filter up towards the transmission with some bulk 5/8 heater hose and installing a new vent solenoid.
Mine does this but it is sporadic at best. It does it more at the local Kroger than it does at regular gas stations. Maybe their pumps are more sensitive.
Has your concern been resolved? Keep me posted and feel free to contact me privately with the last eight of your VIN and I can look into this on my end as well. Thank you.
Tricia, GM Customer Service.
Anyone have a link to this bulletin? I can usually fill mine by tilting they pump handle... Just a pain to fill up not really a big deal...
My 2009 GMC Sierra "100% pure gas" 5.3L never had a filling problem, my 2012 GMC Sierra "FLEX FUEL" 5.3L is a whole nother ANIMAL.
Talk about a pain in the rump putting gas in!! WOW!!!
I've heard & read about filling problems, seen the "yellow" gas caps too. I just figured the flex fuel trucks had a different vent system??? :nonod:
I have a problem filling my tank also.
What I found is if I hold the nozzle up instead of letting it rest the tank will fill.
If I let it rest like you're supposed to it will click off time after time.
It must be the way the fill tube is shaped because it prevents the fuel from going straight into the tank and causes the fuel to create a back pressure on the nozzle and it senses that the tank is full and clicks off.
It happens at almost every gas station so I know it is not the nozzle.
Is this the same problem everyone is having?
Yup, I've had that happen at several stations. Those stations that deliver at lower speeds tend to be ok. However, the higher flow rates at other stations, I end up holding the pump handle up a bit. Sometimes I end up also pulling the handle out just a bit AND hold it up if it's being pumped in too fast.
I'll try this tip out next time.
I know it seems to help "some" when I always make sure the nozzle is dead straight inline with the filler spout...
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
