clunking intermediate steering shaft
I have an '06 crew cab Z71 4X4 Silverado 1500 with really low mileage (less than 20k) which I bought new. The intermediate steering shaft on the truck finally began to clunk when driving over grass or slightly uneven surface. Someone mentioned that GM supposedly replaced these shafts even on older trucks due to them being defective. Well I tried to get it replaced and my local Chevy dealer told me to go pound sand. The guy in the service department, upon hearing that this is an '06 truck even remarked: "All warranties must end sometimes." Well, this is my answer to GM: You deliberately installed defective steering shafts in these trucks, knowing full well they will clunk prematurely and devised a stupid and ineffective bandaid fix by selling a grease kit instead of recalling the trucks and replacing these shafts with a properly designed one. It is up to me now to shell out a couple hundred dollars for the part and labor to fix what you should have fixed under a recall campaign. And hope that the new shaft will hold up for more than 20k miles. I had a 1999 Mazda 626 which I also bought new and the ORIGINAL steering shaft was solid and clunk free even after 339,000 miles when I got rid of the car! How is that for quality comparison? And I have not babied that car. My truck on the other hand was never off road, other than the grass on my lawn.
Thanks GM, you provide an outstanding incentive for someone like me to buy a new GM truck! I must be guilty of not putting enough miles on my truck to take advantage of having a known defective component replaced while the truck was under its original 3/36 warranty.
You expect GM to cover something on a 7 year old truck? Regardless I don't think they ever offered any kind of extended coverage on the ISS. Some dealers may have goodwilled it but that's all. You can try unbolting the ISS underhood and compress/extend the shaft several times as a temporary fix (GM referred to this as "exercising" the shaft...) but a new one was $100 when I replaced it in my 2003. Easy job. And the shaft was redesigned in 2006/7, I replaced mine. And recalls are only done generally for safety issues, which this is not.
Recalls are for safety issues, the steering shaft clunk is not a safety issue.
Ryan
Recalls are for whatever the company wants them to be for. True, only safety issue recalls are mandated by the NHTSA, but that does not stop any manufacturer from voluntarily replacing a known defective component.
I guess I was irritated by that guy's remark that "all warranties must end sometime". And so must my business with that dealer.
It is the principle of using a known defective component in a vehicle and hoping that they never have to replace it under warranty that irritates me. I can do the job and replace it, no big deal.
I will unbolt the shaft and try compressing it first.
It is an annoyance issue and not a safety issue. I replaced mine myself. Easiest way is to unbolt the gas pedal and bracket. That gives a lot more room.
Btw don't forget the cheese for them crackers, haha
had 2 replaced on my 2006 w/76k on it.....$149.00 otd @ the dealer ship
still haven't found a fix the the groan coming from the steering coulum when turning left.....
any new trucks 2012-2013 with this same problem?
I'm not aware of any of the 900-series trucks having the same issue.
When you're down there unbolting the iss, be sure to grab the steering column. If it really rattles, the bushing at the end of the steering column might be bad. I changed mine out and found it really quieted things down/eliminated a vibration in the steering wheel. The old bushing is white, the redesigned bushing will be green.
I purchased my 2006 Silverado in 20012 and am the 2nd owner. My shaft started clunking. Dealership has a program that GM pays half and customer pays half. GM knows there was a issue with the intermeidate shaft and that is the program that is there. Did not cost me hardly anything to have dealer do it. Think my part was 50 bucks. And i have 43,000 miles or so when this happened.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
